Scratched Interior Handles
synchro
Postby synchro » Sat Mar 05, 2011 1:40 pm
My interior handles were annoying me as they are scratched and spoil the rest of the interior
which is great. I was going to remove them and paint them, but thought it would be tricky
to match the creamy colour. So I thought I'd try some 3M carbon film after seeing some clips
on you-tube. Only took half an hour per side. Let me know what you think of the results.
I think they're much smarter!
Before (Passenger side example
https://www.flickr.com/photos/58074387@N07/5498920339/
After (Drivers Side)
https://www.flickr.com/photos/58074387@N07/5498920365/
https://www.flickr.com/photos/58074387@N07/5498920393/
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Re: Scratched Interior Handles
Postby Boomstyliemikey » Sun Mar 06, 2011 5:53 pm
That looks really good. I have the same problem in mine. Could you please post the link to the youtube video on how to do that.
synchro
Postby synchro » Sun Mar 06, 2011 7:22 pm
No specific clips for a Megane, but search for 3M di-noc and you can see examples
of the film being applied. I might try the front badge a bit later.
Boomstyliemikey
Postby Boomstyliemikey » Sun Mar 06, 2011 8:21 pm
That's a top idea. If you do put a pic up here for us to see it
willholdsworth
Currently Drives:: 59 plate Megane cc Dynamique s
Postby willholdsworth » Mon Mar 07, 2011 10:53 am
Nice work, they did look terrible as they were, 100% better now
Image Owner of a 59 Plate Chipped 1.9dci CC + Inferno Orange Megane Sport 225
synchro
Postby synchro » Mon Mar 07, 2011 5:58 pm
I did the front badge:
https://flic.kr/p/9oza1T
Really need to remove it to do a better job, but it looks ok. I might do the rear too.
Anyone know how to remove the rear badge?
Probably call it a day then on the carbon film. Less is more!
JasonS
Postby JasonS » Tue Mar 08, 2011 1:35 pm
I've got a sheet of that stuff left over, I might have a go at the same.. my interior is grey leather, so it won't show as much, but will tidy it up somewhat.
2005 Megane CC Monaco 1.9dci 130
synchro
Postby synchro » Sun Mar 13, 2011 7:13 pm
Now I've done the rear badge:
https://flic.kr/p/9q4dVB
I wonder if I should paint the Megane letters black to match?
Boomstyliemikey
Postby Boomstyliemikey » Sun Mar 13, 2011 9:41 pm
I reckon painting it could get messy. Could u not wrap them in the film? I'm still waiting to get my car back to do mine
mattyc25
Currently Drives:: megane mk2
Postby mattyc25 » Fri Jun 03, 2011 10:41 am
how do all these parts come off to wrap?
Interior handles? exterior diamond badges? gear stick surround?
Anyone?
Matt
ChrisM
Postby ChrisM » Fri Jun 03, 2011 1:20 pm
Stupid idea from Renault, make a black plastic grab handle then paint it beige! and how long will that last, considering the amount of beige interiors thay have on the megs would it have really been that expensive to cast the whole handle in beige plastic, opposded to casting in black plastic then colouring it as well, again with them it is that small issue with detail that they always seem to fail on, I have found it worse on the Meg 2 you would almost say they have an attitude of "oh that 'l do" you know issues with window motors at the bottom of the regulator acting as a drip rail, HUDs with stuck on ribbon cables ontop of the dash where they bake and the ribbon cable is folded in such a manor that all the presure of the ben is on the glue, front deat belts can't be reached if you push your seat forward (shorter people) Handbrake throttle leaver designed to fail via a small screw in a plastic fixing, once this screw works its way out or the platic hole enlarges through hand brake operation, the hand brake is then rendered "in op"
I think the list must be endless. No doubt not much larger than other makes now, seems to be the way they are made now, I was passed yesterday by two TR6,s an old convertable jag, and a very old MG, my first thought was nice! then bet my car lasts nowhere near as long as them... :-(
mattyc25
Postby mattyc25 » Fri Jun 03, 2011 5:07 pm
build quality was never really a renault strong point, nor electrics, nor design.. nor...
i'll stop at that i think.. i'll be here all night otherwise.
Sadret89
Postby Sadret89 » Sun Jun 05, 2011 5:04 pm
did u need to remove the door card to take the handle out?
As I realise when I sprayed the outer parts, the inside bit had 3 screws screwed in facing outwards
mattyc25
Postby mattyc25 » Sun Jun 05, 2011 8:28 pm
the handles you just pull them as if you were opening the door, once the handle is pulled back, slide it towards the rear and it clips off..
My drivers come off by accident all the time. Had it repplaced twice but it still does it, so clipping it back on is a daily process
Matt
ChrisM
Postby ChrisM » Tue Jun 07, 2011 9:15 am
This is Renaults way of making you feel at closer to your vehicle..... :D
