dpf removal
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
dpf removal
Postby Boomstyliemikey » Wed Jan 26, 2011 3:11 pm
So i got my soot filter regenerated 2 months ago when I bought the car off Renault. Its come up again as regenerate soot filter and when I took it back to them apparently they wanna charge me £189. I'm not paying almost £200 every couple of months for them to do this so decided to get it removed. At first i was getting quotes for £450 but after ringing round I've managed to get it done for £150 (cheaper than what renault were charging to just regenerate it) Getting to done tomorrow so will let u know how it goes
davet47
Currently Drives:: 06 Megane CC 1.9dCi
Re: dpf removal
Postby davet47 » Wed Jan 26, 2011 3:56 pm
My local dealer told me to drive at least 15miles above 50mph(keep revs above 2000rpm) and this cures it-well it has done for me. I don't do long trips so once a month I just blast it down the motorway for 25 miles or so. I've only had the "regenerate soot filter" warning twice in 12 months and the last time an 8 mile trip home from work cured it.
Boomstyliemikey
Re: dpf removal
Postby Boomstyliemikey » Wed Jan 26, 2011 7:53 pm
Eddie- wrote:you on about the egr vaule ?
no the diesel partical filter or FAP if ur french lol
Re: dpf removal
Postby Paddy » Wed Jan 26, 2011 9:01 pm
Alot of folk remove them,
especialy on the derv 175. ktec do a kit with the pipe and sensor fitting.
MOT wont be a problem... however the enviroment may bite you in the ass for it...
stu2art
Currently Drives:: megane 1.9 dci (130bhp)
Re: dpf removal
Postby stu2art » Fri Jan 28, 2011 1:55 pm
hello just wondering if any one knows if removing the fap woueld help the performance ever so slightly lol ?? and were did you find to get it removed for that much ?? sounds cheap to what i have read before?
Boomstyliemikey
Re: dpf removal
Postby Boomstyliemikey » Fri Jan 28, 2011 7:18 pm
stu2art wrote:hello just wondering if any one knows if removing the fap woueld help the performance ever so slightly lol ?? and were did you find to get it removed for that much ?? sounds cheap to what i have read before?
the cars been remapped but since the dpf removal it flys. Even the guy who removed it was shocked how quick it moves. It has also really helped on mileage. I was getting quotes for £450 then I tried the guy who remapped the car and he said £300. I think I was just lucky and got a really good deal. In theory I was told you shouldnt pay any more that £100 to the DPF taken off the ECU and £60 to physically remove it so maybe cheaper going to two different places.
123*reggie
Currently Drives:: Renualt megane 1.5cdi (80 dyo) blue
Re: dpf removal
Postby 123*reggie » Sat Jan 29, 2011 2:45 pm
Were abouts is the dpf located ?
stu2art
Re: dpf removal
Postby stu2art » Sat Jan 29, 2011 3:50 pm
Aaaah right I think I may have to look around and see if can find some were cheap to do it lol. Thought it may improve performance as it must block the exit pipe slightly to collect the soot.
Re: dpf removal
Postby davelowe » Sat Jan 29, 2011 10:38 pm
I think some re-mapping firms include a firmware change to the ECU to ignore the DPF. I don't know if it needs physically removing, however.
rossjc
Currently Drives:: Astra VXR
Re: dpf removal
Postby rossjc » Sat Jan 29, 2011 10:51 pm
So you can now have it removed and not have "check emissions" on your dash?
I wanted this done, just didn't like the idea of the warning light (Would do me head in)
Boomstyliemikey
Re: dpf removal
Postby Boomstyliemikey » Sun Jan 30, 2011 5:40 am
rossjc wrote:So you can now have it removed and not have "check emissions" on your dash?
You can either have them just remove it off the ecu so no warning light will come on. However you wont notice any gains and in the long run will probably nack ur car up. Or you can actually have the DPF physically removed and taken off the ecu so no warning light will come on and sorts the problem out permanently
Boomstyliemikey
Re: dpf removal
Postby Boomstyliemikey » Sun Jan 30, 2011 7:20 am
123*reggie wrote:Were abouts is the dpf located ?
The video at the bottom of the page shows where it is on this car if u watch it all the way through to the end
http://www.renault.co.uk/about/innovations/fap.aspx
rossjc
Re: dpf removal
Postby rossjc » Sun Jan 30, 2011 1:21 pm
Thanks, Who removed it off the ecu for you? I know even K-tec say they are still waiting for an ecu upgrade to stop the error.
Users browsing this forum: Google Adsense [Bot] and 22 guests
