dpf removal
- Boomstyliemikey
dpf removal
So i got my soot filter regenerated 2 months ago when I bought the car off Renault. Its come up again as regenerate soot filter and when I took it back to them apparently they wanna charge me £189. I'm not paying almost £200 every couple of months for them to do this so decided to get it removed. At first i was getting quotes for £450 but after ringing round I've managed to get it done for £150 (cheaper than what renault were charging to just regenerate it) Getting to done tomorrow so will let u know how it goes
- Currently Drives:: 06 Megane CC 1.9dCi
Re: dpf removal
My local dealer told me to drive at least 15miles above 50mph(keep revs above 2000rpm) and this cures it-well it has done for me. I don't do long trips so once a month I just blast it down the motorway for 25 miles or so. I've only had the "regenerate soot filter" warning twice in 12 months and the last time an 8 mile trip home from work cured it.
- Boomstyliemikey
Re: dpf removal
Eddie- wrote:you on about the egr vaule ?
no the diesel partical filter or FAP if ur french lol
Re: dpf removal
Alot of folk remove them,
especialy on the derv 175. ktec do a kit with the pipe and sensor fitting.
MOT wont be a problem... however the enviroment may bite you in the ass for it...
- Currently Drives:: megane 1.9 dci (130bhp)
Re: dpf removal
hello just wondering if any one knows if removing the fap woueld help the performance ever so slightly lol ?? and were did you find to get it removed for that much ?? sounds cheap to what i have read before?
- Boomstyliemikey
Re: dpf removal
stu2art wrote:hello just wondering if any one knows if removing the fap woueld help the performance ever so slightly lol ?? and were did you find to get it removed for that much ?? sounds cheap to what i have read before?
the cars been remapped but since the dpf removal it flys. Even the guy who removed it was shocked how quick it moves. It has also really helped on mileage. I was getting quotes for £450 then I tried the guy who remapped the car and he said £300. I think I was just lucky and got a really good deal. In theory I was told you shouldnt pay any more that £100 to the DPF taken off the ECU and £60 to physically remove it so maybe cheaper going to two different places.
- Currently Drives:: Renualt megane 1.5cdi (80 dyo) blue
Re: dpf removal
Were abouts is the dpf located ?
Re: dpf removal
Aaaah right I think I may have to look around and see if can find some were cheap to do it lol. Thought it may improve performance as it must block the exit pipe slightly to collect the soot.
Re: dpf removal
I think some re-mapping firms include a firmware change to the ECU to ignore the DPF. I don't know if it needs physically removing, however.
Re: dpf removal
So you can now have it removed and not have "check emissions" on your dash?
I wanted this done, just didn't like the idea of the warning light (Would do me head in)
- Boomstyliemikey
Re: dpf removal
rossjc wrote:So you can now have it removed and not have "check emissions" on your dash?
You can either have them just remove it off the ecu so no warning light will come on. However you wont notice any gains and in the long run will probably nack ur car up. Or you can actually have the DPF physically removed and taken off the ecu so no warning light will come on and sorts the problem out permanently
- Boomstyliemikey
Re: dpf removal
123*reggie wrote:Were abouts is the dpf located ?
The video at the bottom of the page shows where it is on this car if u watch it all the way through to the end
http://www.renault.co.uk/about/innovations/fap.aspx
Re: dpf removal
Boomstyliemikey wrote:rossjc wrote:So you can now have it removed and not have "check emissions" on your dash?
Thanks, Who removed it off the ecu for you? I know even K-tec say they are still waiting for an ecu upgrade to stop the error.
