I have a 1.6 meg II hatchback.
I have just ordered the relevant EIbach pro lowering springs.
Basically, I plan on installing these myself on the driveway. I already have 2 jackstands and 1 2T hydraulic jack. I will buy a torque wrench that covers a decent range of settings and a set of spring clamps before any work begins. I also have a decent socket set.
Can you please tell me if there is anything else i will need and PLEASE can someone either give me instructions to follow or at least point me in the direction.
I would like to know how this is done, in reasonable detail to help repel my bad luck.
Regards,
Dave
How to fit lowering springs
- Currently Drives:: Megane 2, 1.6 VVT Dynamique
- Ray
- Site Admin
Re: How to fit lowering springs
since you have the tools, buy a haynes manual. save you a bit on labour from garages.
skylinelover wrote:Hi,
Regards,
Dave
Before i did mine i just watched a few videos on youtue. Once you have seen one car down you will get the gist. Its really not a very hard job.
Just becareful taking out the spring as even when the cars up in the air there is still quite a bit of potential energy in it, enough to cause serious pain!!!
- Anthony
- Rally Driver
That sounds as if you speak from experience Ulrich
Anthony wrote:That sounds as if you speak from experience Ulrich
I am. Sore thumb.
Ok guys,
Will a haynes manual for the phase 1 meg 2 be suitable as mines a phase 2 and thats all i can find.
Without having a manual i really wont know what needs to come off to do this.
Someone please take the time to give at least some instructions.
Go to youtube and look for lowering spring replacement.
It really is a simple job. Once you get your head under the 'hood' it all becomes clear as day what had to be removed.
I had never done it before, watched a couple of videos, gave it a go and saw it was childs play. ( given i had a rather sore thumb)
thanks Ulrich.
Will give it a go this weekend, cant be that hard.
Will be back with questions if i have any.
