air filter
syston1988
Currently Drives:: 1.4 extreme 3door black
air filter
Postby syston1988 » Fri May 01, 2009 9:16 am
ive brought a universal air filter, but cannot get it to fit on my megane mk2 1.4... i took the air box off and the hole is an oval shape insted of circular????? so the adapters wont fit! any ideas??
cheers lewis
anth_dci
Re: air filter
Postby anth_dci » Fri May 01, 2009 10:37 am
put it in the bin and buy a replacement k&n panel filter :tu
syston1988
Re: air filter
Postby syston1988 » Fri May 01, 2009 12:24 pm
cheers dude..wheres the cheapest place to get one from?
anth_dci
Re: air filter
Postby anth_dci » Fri May 01, 2009 1:15 pm
i got mine off ebay, but a quick look on there and i cant see one for a 1.4 on there. Might be worth emailing k&n and checking. The 1.6 one might be the same. Also dont expect much difference in power from an air filter.
downsyndromedhorse
Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Re: air filter
Postby downsyndromedhorse » Fri May 01, 2009 3:01 pm
On the 1.9dci, where is the air filter?
I think mine needs changing but i cant see the box anywhere insight (not looked hard to be honest).
I get some strange shudders and car vibrates under hard acceleration in 1st and second so i'm assuming the air isnt gettting in as fast as it should; that or the fuel filter needs replacing.
anth_dci
Re: air filter
Postby anth_dci » Fri May 01, 2009 3:26 pm
on the dci the air filter is directly behind the battery and ecu. There are two screws in the top of it then the encloser pulled up and out bringing the filter with it. 5min job max
downsyndromedhorse
Re: air filter
Postby downsyndromedhorse » Fri May 01, 2009 4:56 pm
Good man, i shall have a look later on.
downsyndromedhorse
Re: air filter
Postby downsyndromedhorse » Sat May 02, 2009 5:01 pm
Found half a pheasant in the air filter, pretty sure that was the problem!
anth_dci
Re: air filter
Postby anth_dci » Sat May 02, 2009 7:25 pm
i found a branch of leaves in mine when i last checked it< cant be doing any good so ive been checkin and cleaning it every 2 weeks to keep it at its best
busternlouie
Currently Drives:: '05' Megane 2.0 VVT Dynamique
Re: air filter
Postby busternlouie » Sat May 02, 2009 10:01 pm
downsyndromedhorse wrote:Found half a pheasant in the air filter, pretty sure that was the problem!
Which half?
downsyndromedhorse
Re: air filter
Postby downsyndromedhorse » Sun May 03, 2009 9:30 am
Mangled legs and arse. but no head!!
busternlouie
Re: air filter
Postby busternlouie » Sun May 03, 2009 10:09 am
Ouch! Bloody kamikaze pheasants!
