in dash cd changer
pmoss
in dash cd changer
Postby pmoss » Fri Sep 21, 2007 3:11 pm
hi,
could anybody tell me if this will work with my head unit (54 reg tuner list cd standard cd HU)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250166872158
cheers,
Pete
1.6 VVT Dynamique Sport Hatch 'Flame Red' on 17" Nervasports .... nice!
renier
Postby renier » Sat Sep 22, 2007 7:48 am
Hi
Think it will work, but not sure. Connection is the correct one (8 pins blue mini Iso, see other e-bay item below), but then still, it might not work. You could give it a try and if it isn't compatible, re-sell it again on e-bay.
Good luck! :D
https://cgi.ebay.nl/RENAULT-LAGUNA-2-IN- ... otohosting
kmarty
Postby kmarty » Mon Sep 24, 2007 11:38 am
renier wrote:Connection is the correct one (8 pins blue mini Iso, see other e-bay item below), but then still, it might not work.
Unfortunately, connection is same on both cases. Analog or digital, both using "blue mini ISO" (and on same pins!).
MEGΛNE Expression Grand Tour/Grandtour/Estate/Tourer 1.6 automat - 2005
sorry for my poor english
Image (Image)
cactusbob
Postby cactusbob » Mon Sep 24, 2007 2:36 pm
The CD changer will work with both UpdateList and TunerList head units. Make sure that whichever one you get has the interconnecting cable and the code for the unit (usually the same as the original headunit it was hooked up to)
225 5dr FF + Xenons
http://www.meganesport.net
hoendy
Currently Drives:: Megane coupe
Re: in dash cd changer
Postby hoendy » Sat Jan 03, 2009 10:05 pm
Does anyone know if the in dash 6 disc changer is compatible with aftermarket HU's or is it updatelist compatible only? I want to upgrade HU and keep in dash chnager?? Any advice would be welcomed. ta............ :-)
Gav
Postby Gav » Mon Jan 05, 2009 12:51 pm
hoendy wrote:Does anyone know if the in dash 6 disc changer is compatible with aftermarket HU's or is it updatelist compatible only? I want to upgrade HU and keep in dash chnager?? Any advice would be welcomed. ta............ :-)
The changer communicates with the head unit using the protocol by VDO-Dayton, and the audio is sent using S/PDIF. If a replacement head unit talks the same protocols then it will work.
Users browsing this forum: Google Adsense [Bot] and 6 guests
