cuttig out when cold
kirky
Currently Drives:: megan 1.6 dynamique
Postby kirky » Sat Oct 25, 2008 3:32 pm
have had my megane 3 weeks and has just started stalling when cold and runs a bit rough at low revs as this is my first renault am reluctant to take it to a main dealer have heard lots of bad things its a 1.6 vvti manual 5 speed
tom85
Currently Drives:: megane 1.6 16v Dynamique (2003)
Re: cuttig out when cold
Postby tom85 » Sat Oct 25, 2008 5:03 pm
u need to specify engine type/transmission.
tom85
Postby tom85 » Sat Oct 25, 2008 5:30 pm
when it cuts out does it restart ok
kirky
Postby kirky » Sat Oct 25, 2008 5:40 pm
yes starts straight away have to keep revs a bit high for a min till engine gets warm then ok just a slight juder as you excelerate between 1500 and 2000 revs
tom85
Postby tom85 » Sat Oct 25, 2008 5:44 pm
crank shaft position sensor or as Renault call it TDC sensor, had same fault wiv mine. Approx £25 to buy. Easy to replace yourself
kirky
Postby kirky » Sat Oct 25, 2008 5:51 pm
thanks for than info will give that a try dont have much faith in main dealers
kirky
Postby kirky » Tue Oct 28, 2008 9:12 pm
well have replaced the sensor and still the same have been reading lots of reports on this problem and it seems a fault that wont go away in most cases
markren2004
Postby markren2004 » Wed Oct 29, 2008 8:23 am
kirky wrote:well have replaced the sensor and still the same have been reading lots of reports on this problem and it seems a fault that wont go away in most cases
was thinking of changing my TDC sensor...ive heard there quite tricky to get to...how did you change yours....from the top or from underneath and did you have to take off any bits to get access ?
on your specific issue...is it stalling just at start-up or after you move away and come to a junction ? mine starts fine...idle's fine..but when you first press accellerator it dies (or it does if you don't manage to catch it...once revs have recovered it's fine again - weird.)
kirky
Postby kirky » Wed Oct 29, 2008 5:08 pm
i took it to a friend who has a small garage nothing to tech he said it was not too bad to change if thats anything to go by as for my car its starting to get worse maybe cos its gettig colder i dont know still cuts out when cold until warm but is now running rough in evey gear below 2000 rpm and on motor way above 5000 rpm got spluttery and the warning light came on oonl for a min at most then went out has any body have any ideas
kirky
Postby kirky » Sat Nov 08, 2008 3:56 pm
well still no joy with this car had it plugged into a computor no faults recorded has stopped cutting out though when cold but still splutters in 2 nd 3rd and 4th at low revs below 2000rpmjust feels like the engine is holding back its starting to really bug me now feel like i will never solve this
Users browsing this forum: Google [Bot] and 30 guests
