overheating
sparkz
Currently Drives:: black 1.4 16v mk2 megane
overheating
Postby sparkz » Tue Jun 14, 2011 9:18 am
Hey guy. Having nothing but problems with megane these days. On the way to work today i noticed that the temp guage was really high. I have 3 ideas what it could the water pumps gone, one of tje pipes is blocked or the thermastat is nacked. has anybody got anymore insight. All and any help welcome
20vturbo
Re: overheating
Postby 20vturbo » Tue Jun 14, 2011 7:38 pm
radiator could be leaking, air lock. when u turn the car off can u hear/see the water bubbling?
sparkz
Re: overheating
Postby sparkz » Wed Jun 15, 2011 2:15 pm
I havent seen it doing that mate.
tomalamix
Re: overheating
Postby tomalamix » Wed Jun 15, 2011 10:32 pm
Hy there
For now you should check the coolant level. Post back your results
sparkz
Re: overheating
Postby sparkz » Thu Jun 16, 2011 4:57 pm
ok lads i checked for leaks theres non, the coolant level hasnt changed, i have to say i has to be the water pump thats has packed in, so what prices am i looking at for gettin that repaced, and is worth just doing the pump or th pump and belts
Re: overheating
Postby davelowe » Thu Jun 16, 2011 9:35 pm
If you are going to replace it, do the belts while your in there. It seems very odd that it just simply stopped. Looking back at the design, the only thing that could have happened is that the impeller has come off. I would have thought the roller on the outside would drop off and you would lose all timing... Odd. You are absolutely sure there are no other problems?
tomalamix
Re: overheating
Postby tomalamix » Fri Jun 17, 2011 10:12 pm
a thermostat fault could cause this situation. if it gets stuck when it should open it may cause an overheating problem
Users browsing this forum: Google [Bot] and 35 guests
