Heater Problems
Heater Problems
The heaters on my car have stopped working! before they would only work on highest setting, and now nothing. any1 know where i should look first.
Re: Heater Problems
The resistor pack on the back of the motor (access from passenger side foot well).
Re: Heater Problems
Yes. Although you could meter the voltages on the end of the connector first to rule out other problems.
Re: Heater Problems
hi, i looked in passenger footwell but there is nothing there, do u have a picture of where it is.,
Re: Heater Problems
It's inside the centre console. Access is by removing trim (and maybe the glove box) from the passenger side.
Re: Heater Problems
Ive checked the fuse and it was blown! but now when i turn the heaters on i heard a "thud" noise almost as tho the heater is blocked, is there anyway to access the fan as my window was smashed and i think some glass might have got into the fan.
Re: Heater Problems
Go in from the driver's side next to the clutch pedal. There is an air filter behind a pull off piece of trim. Remove the filter and insert a vacuum hose. I filled a Dyson once doing that! Should be the same on the CC as other models...
