Heater Problems
20vturbo
Heater Problems
Postby 20vturbo » Fri Jun 03, 2011 6:07 pm
The heaters on my car have stopped working! before they would only work on highest setting, and now nothing. any1 know where i should look first.
Re: Heater Problems
Postby davelowe » Fri Jun 03, 2011 9:38 pm
The resistor pack on the back of the motor (access from passenger side foot well).
20vturbo
Re: Heater Problems
Postby 20vturbo » Sat Jun 04, 2011 12:53 pm
do i change it?
Re: Heater Problems
Postby davelowe » Sat Jun 04, 2011 9:30 pm
Yes. Although you could meter the voltages on the end of the connector first to rule out other problems.
20vturbo
Re: Heater Problems
Postby 20vturbo » Mon Jun 06, 2011 10:47 am
hi, i looked in passenger footwell but there is nothing there, do u have a picture of where it is.,
Re: Heater Problems
Postby davelowe » Wed Jun 08, 2011 9:39 pm
It's inside the centre console. Access is by removing trim (and maybe the glove box) from the passenger side.
20vturbo
Re: Heater Problems
Postby 20vturbo » Sun Jun 12, 2011 1:10 pm
Ive checked the fuse and it was blown! but now when i turn the heaters on i heard a "thud" noise almost as tho the heater is blocked, is there anyway to access the fan as my window was smashed and i think some glass might have got into the fan.
Re: Heater Problems
Postby davelowe » Sun Jun 12, 2011 9:36 pm
Go in from the driver's side next to the clutch pedal. There is an air filter behind a pull off piece of trim. Remove the filter and insert a vacuum hose. I filled a Dyson once doing that! Should be the same on the CC as other models...
20vturbo
Re: Heater Problems
Postby 20vturbo » Mon Jun 13, 2011 11:57 am
Thank you davelowe.
