Horn
taffy4462
Horn
Postby taffy4462 » Wed Apr 13, 2011 8:25 pm
Could anyone please tell me if standard air horns would fit my megane 2005 model thank you : )
Re: Horn
Postby davelowe » Wed Apr 13, 2011 9:29 pm
Yes, provided:
1) You can physically fit them
2) They are 12V
3) They don't exceed the fuse rating for the original horn (some do, and of course, the fuse blows)
taffy4462
Re: Horn
Postby taffy4462 » Fri May 13, 2011 3:28 pm
thanks for that Dave . do you know if I've got to take the front bumper off to do this ?
Re: Horn
Postby Paddy » Mon May 16, 2011 8:54 pm
I use a Stebel Nautilus horn
Its a direct fit and it loud, so very very loud.
Re: Horn
Postby Anthony » Tue May 17, 2011 6:38 am
You should have used a relay when installing the Nautilus. The standard circuit isn't graded for the current the air horn pulls.
taffy4462
Re: Horn
Postby taffy4462 » Thu May 19, 2011 12:04 pm
Thank guys will have to look for that horn! :-)
Re: Horn
Postby Paddy » Thu May 19, 2011 4:03 pm
Anthony wrote:You should have used a relay when installing the Nautilus. The standard circuit isn't graded for the current the air horn pulls.
Hmm that could be why it doesn't work at present. Despite the fuse being intact / the horn working on direct 12V. But press the horn button and nothing. I have been looking for the source of the problem for a week now.
I saw that relay in the box. Went with the box to the bin. Prehaps a mistake on my part. :banghead
Re: Horn
Postby Anthony » Thu May 19, 2011 4:48 pm
You can just pick another up from halfrauds for around £3 i think. No biggie.
Re: Horn
Postby Paddy » Thu May 19, 2011 9:00 pm
No Its not the horn itself. I have tried it in work on a DC power pack. Works fine.
The fuse in the circuit is fine.
But when all is connected and I press the stearing wheel button... nothing.
Its doing my head in, getting to the bottom of it!
:banghead
Re: Horn
Postby Anthony » Thu May 19, 2011 9:03 pm
Ment another relay but ok lol
Re: Horn
Postby davelowe » Thu May 19, 2011 9:32 pm
Paddy,
I assume you have checked the voltage at the horn when the horn is supposed to be active.
Re: Horn
Postby Paddy » Thu May 19, 2011 10:16 pm
Yea got a friend to hold a multimeter to the wires.
When I press the horn. Not a thing.
I just can't understand it.
Unless the the rotary switch problem have some how parted the slip ring for the horn?
Re: Horn
Postby joeishmather » Fri May 20, 2011 5:01 am
That's possible, unlikely tho IMO, your probably best taking the airbag out and steering wheel off and having a look about to see what's what! :-)
