***DE Cat Pipe*** Where can you buy 1?
balmer
Currently Drives:: 1.9 dci
Postby balmer » Sat May 07, 2011 6:49 pm
Anybody know where u can get a de cat pipe for the 1.9 DCI?
Re: ***DE Cat Pipe*** Where can you buy 1?
Postby Anthony » Sat May 07, 2011 8:44 pm
No one makes it. Best you can do is knock the guts out of a standard cat.
balmer
Postby balmer » Sun May 08, 2011 10:57 am
Anthony wrote:No one makes it. Best you can do is knock the guts out of a standard cat.
Thanks for the reply!!
Really?? Badtimes!
Is the CAT not on the maniford on the DCI's?
Postby Anthony » Sun May 08, 2011 11:23 am
It is bolted directly to the turbo. Take the plastic engine cover off and have a peek down the back the engine with a torch.
balmer
Postby balmer » Sun May 08, 2011 3:50 pm
bit of a nightmere job then...
have u done urs???
Postby Anthony » Sun May 08, 2011 5:06 pm
No it isn't a difficult job at all really. Everything is quite exposed and easy to get too.
I haven't done mine yet but it is on my list of things to do! :cool:
What I want to do is buy a second hand cat to butcher, don't fancy butchering my own. Then when I come to sell the car I can stick the original back on.
balmer
Postby balmer » Sun May 08, 2011 11:08 pm
Anthony wrote:No it isn't a difficult job at all really. Everything is quite exposed and easy to get too.
OK!!
Sounds like a plan, get 2nd hand CAT from breakers and just pull there inner bits out lol
Better that a remap of £250 getting around 30bhp, when just rip insides of CAT out and get around 15. For about 3rd the price Lol!!!
balmer
Postby balmer » Sun May 08, 2011 11:19 pm
Could be alot hassle when you look at it there!!
Guna have2 gut either ends off, then rip CAT out and weld them back again.
Will the direct heat of the turbo not break the welds????????
Postby Anthony » Mon May 09, 2011 1:19 am
You could try shove something down the left hand hole on that pic. Or I was thinking of cutting a hole in the side of it with an angle grinder and extracting the inards that way.
Btw if you try this you must wear a face mask, the dust created is extremely dangerous! Also, keep the inards to weigh in, it can be worth about £30 alone.
balmer
Postby balmer » Mon May 09, 2011 9:43 am
Going to take it 2 gd exhaust specialist see if they can work there magic!!
My last CAT i sold 2 scrap metal man got £46 :D
BUT! Whats the chances of the service light coming and staying on??????
Postby Anthony » Mon May 09, 2011 9:52 am
You will be fine. There is no lambda sensor on the diesels.
balmer
Postby balmer » Mon May 09, 2011 10:17 am
Sweet!!
Then I'll give u a shout back when I get sorted. Let U know if she goes any better!!
Postby Anthony » Tue May 10, 2011 9:08 am
Nice one bud, looking forward to hearing the results.
balmer
Postby balmer » Tue May 10, 2011 10:38 pm
The results are-BAD lol
Apparently if take it out will put service light on..... :-(
Postby Anthony » Wed May 11, 2011 7:46 am
Why would it? Who told you that?
