1.4 Megane Induction Kit?
blueyees
Currently Drives:: Renault Mégane 5 Door Dynamique 1.4 16v
Postby blueyees » Thu Apr 09, 2009 2:03 pm
Can you get induction kits for 1.4 megane's? I can't seem to find any anywhere. 1.6 is the lowest iv'e seen,
Any help would be appriciated. :)
Nige
Re: 1.4 Megane Induction Kit?
Postby Nige » Thu Apr 09, 2009 3:44 pm
il be keeping an eye out here too.....looking for something for my megane also. Tried K&N and nothing there either other than uprated panel ones.
blueyees
Postby blueyees » Fri Apr 10, 2009 6:54 am
see..i was wondering if the K&N Induction kits for the 1.6 16v fitted the 1.4 16v...as it only a slight upgrade..Not too sure about that though.
anth_dci
Currently Drives:: Megane II DCi 120 Dynamique 52 plate
Postby anth_dci » Fri Apr 10, 2009 11:14 am
all you need to do is measure the size of the throttle body and get one to fit that. I would never recommend one though, they are heatsoak central. Far better of getting a replacement panel filter.
megane09
Currently Drives:: renault megane '04 dynamique, silver, 17 nervasport alloys.
Postby megane09 » Thu May 07, 2009 3:22 am
you do know by putting an air filter kit on your car your really just putting strain on the engine get an uprated panel filter much better without the hassle of the engine problems.
'04 Megane Dynamique, 17' nervasports alloys
Poddy
Currently Drives:: Kia Cee'd 1.6 CRDi
Postby Poddy » Mon May 11, 2009 11:08 pm
you only really get the hassel if you don't fiddle about with the map on the ECU, because of the induction kit, the engine is getting more air but the injectors are pushing in the same amount as before so the Fuel to air ratio is off set, causing problems in the engine.
also any power gains on any car add more strain to the engine.
ive got a Kia Cee'd 1.6 CRDi 90BHP standard, mapped to 140, with a manifold and exhaust comming too, so hopefully upwards of 160bhp from a 1.6 :cool:
07 Kia Cee'd 1.6 CRDi
Remapped
R55VYS
Postby R55VYS » Wed May 13, 2009 11:53 am
very much doubt you will get 20bhp from an exhaust and manifold, show me dyno results and i will gladly eat my words tho, ha ha
R55VYS
Postby R55VYS » Wed May 13, 2009 12:03 pm
if your just intrested in the noise, you can easily make an induction kit, me and a mate made one for his 1.4 106 quicksilver, made from a radiator pipe from a tractor or something massive, to conect pipework to throttle body, got an exhaust place to make a bent bit of stainless pipe to move the filter from the back of the engine to the front and bought a massive universal air filter from somewhere, looked and sounded ace, moddifed it after a bit by making a custom heat shield to wrap around it, not sure if it actually did anything either but looked good when the bonnet was open, and gave a nice induction roar.
Someone with a 225 tested the gains from an induction kit, compared to the standard air box and they found that it lost bhp with the induction kit on, so a replacement pannel filter is what the majority of people do.
But with the 1.4 not being a fast car if you were just bothered about making it sound nice i cant see a problem. just buy a universal one and make it fit or as said check the dia of the throttle bodies to the 1.6 and get that. just if you do put an induction kit on try and get as much cold air to the filter as possible, via cold air feeds, heat shields etc.
Jammie667
Currently Drives:: Megane II Dynamique 1.9 DCI 120
Postby Jammie667 » Wed May 13, 2009 12:29 pm
Green do a range of 1.4 air filters/induction kits matey
Follow This Linky
The top 4 on the list are for the 1.4.
K&N only seem to do a replacement panel filter, the part number is 33-2194.
Enjoy :cool:
'04 1.9 DCI 120 Dynamique - 5Dr Hatch - Metallic Red
Bought 4th April 09
