low revs and poor idle when cold
dougieCC
Postby dougieCC » Fri Mar 13, 2009 8:43 pm
Hopefully someone can help.......the last few days started ok, no noise like described for the dreaded dephaser pully and never stalls. However today started car after standing over night reves drop right down attempt to put a few revs on drops to the point of stalling then picks up, again no rattle just poor cold starting ? dont know where to start. apart from this I love it and averaging 39.9 mpg.
Help
Alan
Its a 1.6vvt
Megane CC 1.6vvt and 1.4 clio
Re: low revs and poor idle when cold
Postby AlexB » Fri Mar 13, 2009 10:22 pm
What oil, filter and mileage since the last service?
dougieCC
Postby dougieCC » Sat Mar 14, 2009 7:09 am
The garage I bought it from serviced it, approx 800 miles ago...dont know what oil there used.
Alan
Postby AlexB » Sat Mar 14, 2009 12:44 pm
Check the stored fault codes and the live engine parameters. If nothing suspicious, then it can be the fuel filter, dirt in the throttle body or dephaser control valve. The latter two options may be related to the use of the "minimum specification" oil.
See the manual for the full algorithm of fault finding (in our Links section).
dougieCC
Postby dougieCC » Sat Mar 14, 2009 1:37 pm
Cheers Alex, will have to get fault reader, will also get decent oil and do a filter change tomorrow. cant seem to find fuel filter on it though...does the 1.6 have one.
alan
p.s...changed spark plugs last night seemed better this morning :?
busternlouie
Postby busternlouie » Sat Mar 14, 2009 2:57 pm
dougieCC wrote:Cant seem to find fuel filter on it though...does the 1.6 have one?
Is it not in or on the fuel tank assy?
dougieCC
Postby dougieCC » Sat Mar 14, 2009 7:59 pm
Reading the haynes manual, its in the fuel tank.....bought some mobile 1 0w40 oil reading specs this should be ok
Alan
nagogg
Currently Drives:: Megane Scénic,R19,Koleos
Postby nagogg » Sat Mar 14, 2009 9:46 pm
Check the Canister bleed solenoid valve.If it is stuck open it draws false air when cold starting
You can check this by blowing and sucking through the valve(if that the case,the valve is faulty)
No service or OBD light comes on when this is the case.I have seen this valve faulty a lot with syndromes like you descripe.
dougieCC
Postby dougieCC » Sat Mar 14, 2009 9:49 pm
Thanks nagogg, where should i look, cant find it listed anywhere.
Alan
nagogg
Postby nagogg » Sun Mar 15, 2009 8:51 am
its on the right side(driver side)black near the bulkhead,with two pipes entering on the top and bottom of the sensor
There are 2 wires on the connector to it.
disconnect everything and try to do what I said earlier
Good luck
Postby AlexB » Sun Mar 15, 2009 11:04 am
You are right, the fuel filter is in the tank and it not serviceable.
Regarding the spark plugs. A special insulating grease must be used every time the coils are removed. There is a Technical Note about it. This may be one of reasons why many cars fail directly after servicing.
I wrote the following to somebody else, but it might be of interest to you as well:
"The sticky stuff is the grease part number 82 00 168 855 applied according to the technical note 3789A. As I understand the coils must not be removed unless one is prepared to renew the grease coating.
The Green Note 4242A is about the coil types. It says that if a SAGEM coil fails and its production date is before "330-3", then all four coils must be replaced by DENSO. It is emphasized that the dates must be checked without removing the coils. If a single DENSO coil fails, then just one coil is replaced."
All original technical information can be found in the Dialogys CDs often sold on ebay. They can be also downloaded from Internet, usenet or p2p networks. A link to PDF docs in our Links.
dougieCC wrote:..cant seem to find fuel filter on it though...does the 1.6 have one.
alan
Postby AlexB » Sun Mar 15, 2009 11:21 am
dougieCC,
What about cleaning the throttle body? It is common problem and there exists a tech. note issued by Renault on this subject.
Regarding the dephaser control valve. I guess, it can be affected by dirty oil. However, if it is stuck, then there should be a fault code logged. The feedback to the ECU is provided through the camshaft position sensor.
PS: use only good quality oil filters. The OEM Purflux is one of the best in the sense that its filter element area is the largest and it does collapse (thus sending the accumulated dirt into the system).
dougieCC
Postby dougieCC » Sun Mar 15, 2009 3:26 pm
Cheers AlexB, will check it out friday when I plan to do oil and filter, after popping to renault for the filter and sump washer. The car started fine today as it was warmer.
Alan
simba7
Currently Drives:: Renault Megane 1.6 VVT Dynamique 2004
Postby simba7 » Wed Apr 04, 2012 11:20 am
Hi, Did you manage to fix the problem?
tomalamix
Postby tomalamix » Wed Apr 04, 2012 3:33 pm
what have you done so far? just to avoid to repeat the same tasks...
cheers
