Angel Eyes Help...
tokyoflash
Currently Drives:: Megane Mk2
Angel Eyes Help...
Postby tokyoflash » Thu Jan 08, 2009 6:00 pm
Just got a set of Angel eyes fitted, and they look great, but they dont illuminate the road in front of me!!
Does anyone else have a pair fitted, if so what does the beam look like? Becasue the ones I have dont light up the road in front of me, only to the side. It looks like a giant V shaped shadow in front of the car! Ive taken them abck to the garage and they said that they are adjusted as they should be and it must be a problem with the lights themselves.
They are CE approved and fully road legal, but there is no way that this can be the case on these particular lights, its actually dangerous. :banghead
this is the link: https://www.deviantstyling.com/p/231/Renault_Megane_Black_Angel_Eye_Halo_Ring_Projector_Headlights
Andy_CC
Currently Drives:: Megane CC and Nissan Navara Avantura
Re: Angel Eyes Help...
Postby Andy_CC » Thu Jan 08, 2009 9:07 pm
first off make sure the bulbs are in the right way round (sounds daft, but this can sometimes happen and effect light pattern etc...)
I had a mate with a 3 series BMW and he bought the angle eye rings to fit inside the original headlight, he didnt line them up correctly inside the headlight and they created a big V shaped shadow on the road as they disturbed the projection of the light onto the road, it took a bit of adjustment but we got it right in the end so the beam pattern was as it should be! the angle eye parts of your light my be out???
also check you have wired them up right, the projector (dome, light closest to front grill) is your normal night driving light (dipped beam) and the outer bigger light next to indicator is the main beam, make sure the wires havent got mixed up.
see what adjustment there is on the units, with them having projector lenses, there my be some sort of "focus" adjustment on them as well as beam angle and distance adjustments.
The only other suggestion to try and improve them is get a mates car facing a wall or fence, turn his lights on and with either a marker pen or masking tape, mark his beam pattern and height on the wall, also mark where his front wheels are, try and get your car in the same position, turn your lights on and see how your beam pattern etc... compaires to your mates car, if its out, as it will be, try and adjust then units untill you get somewhere near what you have marked on the wall, i doubt you will get it anywhere as good as the orginal lights.
tokyoflash
Postby tokyoflash » Fri Jan 09, 2009 11:08 pm
Thanks guys! Ill look into it and let you know how it goes!! xx
tallpaul
Postby tallpaul » Thu Jan 15, 2009 10:34 pm
i changed the headlights for angel eyes on my 306 and they were crap, i guess they're more 'fashion over function'!
