Car wont start? Possibly a simple one!
meccano04
Postby meccano04 » Sun Jul 20, 2008 10:33 pm
Hey
Today i went to start the car (53plate 1.4) and when i pressed the button the ?ignition? just chugged away but the car didnt start for a good while, i stopped the car again, then tried to start the car but this time it chugged away and i got nothing, the car stopped and the battery light came on. Eventually i got it started tho...
I think the battery is fine, its one with a wee led on it to check the status, and after i took it a drive, i stopped and started it and it started fine.
Its wierd as its done this just once or twice before, could it just be the battery running a little low? Anything i should worry about?
silencer51
Re: Car wont start? Possibly a simple one!
Postby silencer51 » Mon Jul 21, 2008 8:47 am
If the ignition turns but the engine doesn't fire then most probably its the TDC sensor, a very common failure. Its also relatively cheap & easy to replace...
Set dephasers to stall!
meccano04
Postby meccano04 » Mon Jul 21, 2008 9:48 am
thanks, now i know what to look for it'll be a bit easier to search on!
a quick search of this site has said cleaning, is there any substance i should/ should not clean it with?
nickbell69
Currently Drives:: megane 1.9dci priv 53
Postby nickbell69 » Mon Jul 21, 2008 5:18 pm
Regards the little green indicator on the battery. My battery died last week totally dead even after a nights charge yet the green indicator was still there. When i mentioned that to the auto electrician he said they're the biggest waste of time ever and mean nothing!! :shock:
Users browsing this forum: Google [Bot] and 37 guests
