emissons light staying on 2004 15dci
gavinc
Currently Drives:: Silver 2004 15 dci
Postby gavinc » Sun Feb 10, 2008 6:52 pm
:-( Hi how do you reset emissons light on dash or is it a dealer reset some help would be most welcome thanks ...gav 15dci 2004..
silver 15 dci no mods as yet//
TOURER54
Postby TOURER54 » Sun Feb 10, 2008 10:20 pm
I had a similar fault with a vauxhall Astra and by luck- disconnected the battery for another issue and when I reconnected it, the fault light had extinguished??!!
IainMW
Postby IainMW » Mon Feb 11, 2008 7:00 am
gavinc
The light is on for a reason, because it's indicating a fault. You cannot reset it if the fault still exists?
You say in your other post that it came on after filling up with fuel at Tesco's, have you still got the receipt?
Are you sure that you've not accidentally misfueled your car?[/b]
gavinc
Postby gavinc » Mon Feb 11, 2008 7:27 am
no i havent was ok until i fueled up but was diesel any idea,s running just the same,, :-(
gavinc
Postby gavinc » Tue Feb 12, 2008 6:11 pm
IainMW
:D :D Sorted it was the tesco diesel full of bubbles in the line just pumped it and away it went (light out )lol.. will use shell next time..cheers lads :cool:
IainMW
Postby IainMW » Wed Feb 13, 2008 8:27 am
Get your fuel filter checked as there have been some issues with air ingress from the fuel filter housing on 1.5dCi's. Unfortunately the inner wheel arch has to come out to do this so it's probably a garage job uless you are feeling brave?
There should not be bubbles in the fuel lines?
gavinc
Postby gavinc » Thu Feb 14, 2008 7:24 pm
:) Will do feeling brave so will have a look the weekend thanks mate..
Users browsing this forum: No registered users and 70 guests
