More problems
Kev
More problems
Postby Kev » Wed Jan 30, 2008 10:30 am
Hey, as I explained in the "toxic fume filter light" thread, I was having problems with my Megane. I got it last Thursday, on friday the toxic fume filter warning light came on and the car was really sluggush starting up in the mornings.
Anyway, I took it back on Monday and they reset the dashboard computer. Apparently all faults are stored on it and have to be cleared every once in a while. Once this was done the light didn't show up anymore and I was assured it was "100%" and I collected it yesterday.
That was all well and good until I try to start this morning. I put the card in and pressed start. The car doesn't start. "Electrical Fault" appears on the dash as well as the red "STOP" light. I try in vain for an hour to get it started but no joy. I rang my dealer again and they are going to pick it up and have a look at it until its (here's that phrase again!) "100%". In my first week I've had two problems, kinda makes me consider taking it back and getting another car.
Kev
Postby Kev » Fri Feb 01, 2008 9:26 am
Update:
It seems the electrical fault was caused by water getting into the fuse box. The garage told me that a flap at the front wheel was missing and that allowed water to get in and causeed the car to not start. The replaced the fuse box and fitted a flap so it shouldn't happen again.
Hopefully it'll be good to pick up this evening.
Postby Stranger » Fri Feb 01, 2008 10:01 am
Result :-)
onlydiesels
Postby onlydiesels » Fri Feb 01, 2008 5:56 pm
i had similar electrical gremlins, caused by the same thing. quite common.
Alig
Currently Drives:: 2003 megane 1.6 vvt sport
Re: More problems
Postby Alig » Wed May 02, 2012 8:43 pm
Did you have to buy a new fuse box etc, did it need to be reset if it was second hand and how much did you get one for I have the same problem now and did that sort your problem out
weldore
Currently Drives:: megane estate 1.9 dci
Re: More problems
Postby weldore » Wed May 02, 2012 9:21 pm
me too..see my thread :roll:
and i also think its time to fix and get rid .when they work they are a lovely car,shame really isnt it :?
EDIT BY MOD: see here viewtopic.php?f=2&t=19850
[Apologies if this is incorrect - I will make the necessary correction at the earliest opportunity]
Users browsing this forum: No registered users and 92 guests
