do the DCi's have them? my car is showing up a 01648 fault on the diagnostics.
on looking on the net it looks like this fault is actualy P0164 which is a lambda fault apparently.
DCi-Lambda Sensor??
DCi-Lambda Sensor??
- IainMW
Not sure on that one but I suspect they will have exhuast gas monitoring sensors.
The ECU will monitor oxygen in the exhaust. (I think?
Are you sure the two faults are the same?
apparently its not actually that, the fault code is actually P01648 and is CAN-bus failure/malfunction...apparently It relates to general EODBII "P1" codes (They're not shown in Autodata) and the "CAN-Bus" is the interface used in all new Renaults for the ECU to gather info from all the various sensors around the car.
still confused
still confused
Users browsing this forum: No registered users and 86 guests
