sticking accelerator pedal! (edit: Now with some photos!)
pmoss
Postby pmoss » Tue Sep 04, 2007 7:29 am
hi,
well, 4 days in and my megane is already giving me trouble :(
A couple of times now my accelerator pedal has stuck on - almost flat to the floor - causing the engine to rev its nuts off, the first time this rectified itself but this morning I had to stop the car by braking against it and pull the pedal back up by hand!!!
When I had a good look at the pedals in the car I noticed that a lot of the 'gubbins' (technical phrase) attached to the pedals is all exposed - which I found strange as in my old car this stuff was all sealed off - is this normal?
Obviously this is really dangerous and I will be getting it to a dealer ASAP but does anybody know why this should be happening or if it is a known problem?
Thanks,
Pete
1.6 VVT Dynamique Sport Hatch 'Flame Red' on 17" Nervasports .... nice!
Steviebmk2
Postby Steviebmk2 » Tue Sep 04, 2007 9:44 am
My clutch pedal used to do that, then I found out that it was getting stuck on the floor mats. :oops:
Steve Bremner
http://www.stevieb.net
1.6, Charcoal Grey, 2007 Reg, Authentique
pmoss
Postby pmoss » Tue Sep 04, 2007 10:18 am
i did wonder about if it was sticking to the mats but I dont not think it was - is there any way that the pedal could stick to the carpet?
I will try and get a photo of the pedal area later on and post it up to see if it looks in any way "odd" - I do find it strange that some of the linkages and cables seem to be exposed, I am not sure if something is missing and my feet might simply be catching on stuff they should not be!
thanks,
pete
pmoss
Postby pmoss » Tue Sep 04, 2007 11:48 am
Right, just popped out and got some (fairly crap) photos of the area using my mobile - basically all the linkage and wiring stuff seems to all be exposed above the pedals - is this the same on everyone elses Megane?! :?:
thanks,
Pete
R55VYS
Postby R55VYS » Tue Sep 04, 2007 11:57 am
Mine got recalled with something to do with the pedals, think they had to check that they werent to close together, didnt get the letter thru till 6month after i bought the car and apparently the letter had been sent to the guy that owned it before me to.
Users browsing this forum: Google [Bot] and 24 guests
