Replacing Update List stereo in 2005 Megane
GoldenWonder
Postby GoldenWonder » Tue Jul 31, 2007 7:44 pm
I'm new to updating ICE but willing to try! I would like to replace the standard CD player in my 2005 (55) Megane (Update List) with an MP3 stereo such as the Sony GT610U which is a reasonable cost at around £100.
I can get the Fascia and ISO adaptors for around a tenner each, but then asking where to get the steering control adaptor from results in confusion when I ask local factors!
Is there an easy way I can do this? I don't really care whether the in dash display works or not - but I would like to retain the steering controls.
navid.v
Postby navid.v » Tue Jul 31, 2007 9:13 pm
just wondering,don't you have an ipod?as you can connect your ipod to update list via connections like connects2 or Dension Ice link plus.
as I said just a thought. :)
GoldenWonder
Postby GoldenWonder » Wed Aug 01, 2007 8:32 am
Thanks for the reply. I don't have an ipod - would the connectors you mention allow you to control and ipod (or mp3 player) through the steering controls?
navid.v
Postby navid.v » Wed Aug 01, 2007 10:00 am
yes it does,the only thing you don't get with connects2 is the track name! but who cares,sound quality is great and easy to install.if I can do it,anyone can :D
kmarty
Postby kmarty » Wed Aug 01, 2007 2:57 pm
Or Renault Audio Connection Box - TunePoint - P/N: 77 11 419 487:
Image Image
It is almost same (or same) as Dension Gateway 300.
Supports:
  • USB - any USB Mass Storage media (flashdisc, MP3 players or USB harddrive - current cannot be over 500mA) containing:
    • Ogg Vorbis (up to 320kbit)
    • MP3
    • WMA (files w/o DRM only)
    • WAV (PCM only)
  • iPod
  • Anything with audio output on 3.5mm jack. (only volume can be controlled here).
Box is controlled like normal CD-changer.
MEGΛNE Expression Grand Tour/Grandtour/Estate/Tourer 1.6 automat - 2005
sorry for my poor english
Image (Image)
navid.v
Postby navid.v » Wed Aug 01, 2007 3:07 pm
great,did you purchase this direct from Renault?if so,how much did it cost?I am sure there has been a post before about TunePoint before,but nobody did manage to source it :shock:
kmarty
Postby kmarty » Wed Aug 01, 2007 3:18 pm
I purchased it from Renault dealer by P/N because they didn't know anything about it.
Price was approx. £128 at 1. Jun 2007.
You have right, there is(was?) a topic about it and it was start point when I began search about it. Just because I wanted something what can be connected as CD changer, can be controlled as CD changer and can playing Ogg Vorbis format (or at least MP3 format). And TunePoint can do it perfectly.
Image (Image)
GoldenWonder
Update list audio
Postby GoldenWonder » Sun Aug 05, 2007 8:17 pm
This is getting expensive!
I have an older Panasonic MP3 player which I might use instead and see how I manage without the steering controls - its a compromise really.
I've looked and queried the major online ICE resellers and they either didn't reply or offered conflicting answers.
Surely there is a simple (and cheap!) way to use the steering controls with a standard Sony/Pioneer etc unit without resorting to various boxes of tricks to display the minimal information on the dash display? Some of the adaptors I've seen for £100+ simply put the stereo manufacturer name on the display - wow!
When I bought the car I foolishly thought I would need a fascia adaptor, a Sony remote interface and a Renault remote interface - guessing about £50 for the three - how wrong I was!
If I'm spending £200 plus on installing a Sony HU - I'm wondering whether its easier to install the Renault MP3 compatible unit which is around the same price - has anyone any experience of these units?
navid.v
Postby navid.v » Mon Aug 06, 2007 1:04 pm
I bought my connects2 parts from halfords,about £80 for the whole thing.it all depends how often do you want to listen to cd's or mp3's?
GoldenWonder
Connects2
Postby GoldenWonder » Mon Aug 06, 2007 4:32 pm
You don't happen to have the part numbers for the Connects2 items do you?
I spend quite a bit of time in the car and miss the convenience of my old MP3 compatible stereo!
navid.v
Postby navid.v » Mon Aug 06, 2007 9:08 pm
I don't have it but from top of my head,can say it was ARNIPOD003.but to be on the safe side,just visit connects2.com and enter your reg number,it gives you the compatible parts for your car.if still not sure,just drop them an email they are very quick in getting back to you.
hope this helps.
update:the TunePoint by renault is listed in their brochures with the RRP of £175. :shock:
GoldenWonder
Sorted!
Postby GoldenWonder » Thu Aug 09, 2007 7:37 pm
Well, thanks for all the info folks but I've gone for the cheap and easy solution.
With a bit of research (especially on these forums) I've found a Sony CDX-GT30RN unit on Ebay for £60 (new). Fitted it in 5 minutes, works a treat and uses the display and the steering stalk. I'd recommend it to anyone! Almost matches the dash board as well, with a decent sound quality and 3.5mm Aux in jack.
What a con though - this Sony unit was obviously manufactured with Renaults in mind and Renault sell it for £180+, every other ICE seller is knocking them out at £100 or less!
overandunder
Postby overandunder » Tue Aug 14, 2007 5:17 pm
I have just bought an '05 reg Sport Tourer and it has the standard cd/radio, which I think needs an update! Did the Sony you bought just slot straight in and use the existing connections or did you need a set of wiring converters, etc?
Also are you still using the standard speakers, and if so did the Sony unit improve the sound at all?
Thanks.
1.9DCi Sport Tourer
GoldenWonder
Sony
Postby GoldenWonder » Tue Aug 14, 2007 5:51 pm
Yes, the CDX-GT30RN (must have the 'RN') slots straight in with no wiring adaptors. You will need the fascia adaptor though.
The ISO leads from the Update List stereo plug straight in, and the mini-ISO (yellow) connects directly into the back of the Sony as well. There is also a connector for a CD Changer!
This unit must have designed for Update List Renaults as it was perfect swap - even the head unit illumination matches the dash!
As for sound quality, I left the standard speakers in and the sound was better - you have various options to fiddle with, but I'm pretty happy with mine (and I listen to heavy metal!)
I might upgrade the speakers in due time though, but I was just chuffed to get a good MP3 player with steering controls for £65!
overandunder
Postby overandunder » Wed Aug 15, 2007 8:02 pm
Thanks for that, will check it out. Anyone know of any other sets designed with the Megane connectors in mind or is the Sony the only choice (without buying techie spaghetti to make other units work) ?
1.9DCi Sport Tourer
