Fan belt replacement
El85
Currently Drives:: Megane 2004 dci estate
Postby El85 » Mon Aug 19, 2013 7:44 pm
Hello,
This is my first post so please excuse me if I don't put enough information in!!
I have a 1.9dci privilege estate and have been told recently my fan belt is cracked. The belt itself is reasonably cheap and I just wondered if anyone has replaced the belt themselves and if so if its very easy? If not anyone know how much they are roughly to have done as the garages I have contacted have said they'll have to get it in and have a look first.
Thanks in advance for any help.
Elliot
Beast Rider
Currently Drives:: Renault Megane 1.9Dci 120 dimonique
Re: Fan belt replacement
Postby Beast Rider » Tue Aug 20, 2013 8:59 am
It's easy to do with a basic tool kit but there is a lot of coverings to remove before you get to it through the front off side wheel arch.
morganjake1544
Postby morganjake1544 » Tue Aug 20, 2013 9:04 am
Your car doesn't actually have a fan belt. The last car I owned with a fan belt was my beloved Ford Capri 2.0 Ghia (1979 - T Reg). So it is either the timing belt (also called a cambelt) or the accessories belt.
The timing belt kit is probably £100 and best left to a good mechanic and the accessories belt more like £15-£20.
If it is the timing belt that's cracked then it is wise to replace the water pump and accessories belt at the same time. All in you're probably looking at £300 - £350 for a good independent garage to do the job. Double that for a Renault dealership.
The belts should be replaced every 5 years or 72k miles.
Here's a link to the manual, see Section 11A.
http://ray-lee.co.uk/megane/dialogys/MR364MEGANE1.pdf
Beast Rider
Postby Beast Rider » Tue Aug 20, 2013 9:11 am
Most people say "fan belt" when they mean accessory/auxiliary belt
El85
Postby El85 » Thu Aug 22, 2013 5:43 pm
Yes sorry I should have said, it's the accessories belt just use to calling it the fan belt. I have had the Cambelt done about 12000 miles ago. Now there is cracking in the accessories belt so need that replacing, I have found the belt fairly cheap to buy I just wondered if anyone has changed there own belt or whether its a garage job.
Beast Rider
Postby Beast Rider » Mon Aug 26, 2013 7:32 am
It is easy to do yourself, you have to take a lot off before you can get to it though.
Front off side wheel needs to come off, then wheel arch liner, then there is a removable panel with 4 13mm bolts.
With all those removed you can see the belt, it has a self tensioner that needs to be manually moved in order to remove the belt.
Its a fiddly job but easy to do.
El85
Postby El85 » Mon Aug 26, 2013 10:57 am
Thanks very much. I will have a play over the next weekend.
