Grand Scenic II calipers on Mégane II
svelst85
Currently Drives:: '06 Mégane Grand Tour 2.0 dCi 150
Postby svelst85 » Sat Jun 08, 2013 10:41 am
Hi everyone.
I'm the lucky owner of a '06 Mégane II ph.2 Grand Tour 2.0 dCi 150.
A month ago I lapped the infamous Nürburgring with it.
The car held up pretty well, but stock brakes faded very badly after about 2 miles.
When I got home that evening, I was looking into brake upgrades options...
The Scénic II has 300x44x24mm discs (stock Mégane has 280x44x24mm).
Since the Scénic II is pretty much a big Mégane II, can I use the discs, calipers and hoses from it on my car?
Is the Scénic II using other calipers/caliper carriers, or does it have the same calipers/caliper carriers and a different hub? Or both?
(I noticed the 03-06 Scénic II and Mégane II are using different calipers then the 06-09 Scénic II and Mégane II, so IF I need the calipers, I obviously need to use the calipers from a 06-09 Scénic II)
svelst85
Re: Scenic II calipers on Mégane II
Postby svelst85 » Mon Jun 10, 2013 1:45 pm
Nobody that knows the answer?
morganjake1544
Postby morganjake1544 » Mon Jun 10, 2013 4:49 pm
svelst85
Postby svelst85 » Mon Jun 10, 2013 7:54 pm
Because "Wheel studs: 4"
My 2.0 dCi has 5x108
DK-brun
Currently Drives:: Renault Mégane II Tourer, Dynamique 2,0 16v
Postby DK-brun » Wed Jun 12, 2013 5:30 pm
You have to be easy with your brakes on Nürburgring, or else they will fade.
I'm using stock 280mm discs, Ferodo Performance pads and Ferodo Brake fluid 5.1 on my Megane Estate, and it works pretty well with no fading. Brake hard when you need to brake and remove your foot when you are done braking, do not make those long brake entries into corners. That's what make your brakes overheating.
My fastest time yet BtG, is 9:36, with brakes and loweringsprings as only upgrades. My newly fitted Bilstein suspension is to be tested there in about 2 months.
I would just upgrade the standard brakesystem with pads and fluid. I haven't met any troubles with fading yet and i have visited quite a few trackdays in Denmark already.
Kasper Brun
svelst85
Postby svelst85 » Sun Sep 01, 2013 3:45 pm
After a bit of research I'm done upgrading the brakes.
I used the following parts:
- Grand Scenic II 2.0 dCi Bosch rotors (300x24 - 5x108)
- Grand Scenic II ATE calipers and carriers
- Grand Scenic II Brembo brake pads
- ATE super blue racing DOT 4 brake fluid
I'm still bedding them in, but I'm pretty happy so far.
They're a plug and play upgrade and the parts are easily obtainable.
I can always upgrade the Brembo pads to something better if I want.
