I been having issues with the radio reception in my 2007 Priv' for a while and decided to take the car to an ICE specialist in Bury St Edmunds.
Having been unable to remove the head unit as the 6 disc changer wouldn't come out due to the right hand side not releasing, we looked at the aerial and found that where the lead is cable-tied to the hinge mechanism, is has clearly been bent many times and the outer black covering has broken, as has half the wire shielding and possibly in the inner wire too.
Has anyone had this problem before and it so how can the wire be replaced ? Is there a joint in the wire close by or is it one wire that runs all the way to the stereo ?
David
Aerial lead broken in boot
- Currently Drives:: Megane CC 1.9 Privilege
Get your top off !
Re: Aerial lead broken in boot
Hi, was just wondering if you managed to sort this out as I think I've got the same problem.
Our stereo is rubbish. No reception at all. Please let me know.
Thanks Karl.
Thanks Karl.
Sadly not. No responses and no joy in resolving.
Sometimes reception is fine, others it won't find anything.
Sticking to CDs now
Sticking to CDs now
Get your top off !
Thanks for replying. I'll keep searching the forums.
