Right whilst I am doing the rear brakes thought it would be a good time to change the brake fluid also, as I am not sure when this was last done.
Any special things I need to know about when changing? What brand is best to use?
Changing Brake Fluid
Re: Changing Brake Fluid
Just bleed the brakes a bit more than usual. Keep bleeding and topping up until the bled fluid becomes lighter. Don't let air in the system. You will need about 0.7L, buy 1L just in case.
Buy any DOT4 fluid of a known brand. DOT5.1 is compatible and supposed to be better. Under no conditions use DOT5 - it is completely different!
- ikhan
Castrol Response is supposed to be brilliant - never used it mind but I may do when I do mine.
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
Thanks for the replies went for some ATE stuff... Which I had in the M5.... Now the thought of changing the fuel filter at the same time comes to mind!
I also take it that you don't need anything fancy to the fluid change or anything reset? Also what is the capacity of the brake fluid need to change fully?
Users browsing this forum: Google [Bot] and 39 guests
