How to fit a new horn?
tamarisk
Currently Drives:: meegane tourer diesel
Postby tamarisk » Sat Mar 31, 2012 8:57 am
Horn has died and I've got an MOT in a month, I've read it's a pretty easy retrofit, but no-one outlines how you get the front grill off, the official advice I believe is removing a lot more body parts. Any pointers, the advice I've read so far is a bit unclear. Cheers
Re: How to fit a new horn?
Postby AlexB » Sat Mar 31, 2012 12:49 pm
Remove the bumper as described in the manual. It is easier than you may think... and even easier that you will think after reading this post.
Postby davelowe » Sat Mar 31, 2012 10:24 pm
Don't break the upper clips when you take it off - an assistant and patience are both required. Also, compare the fuse rating for the new unit with its amperage. Otherwise, you will get a short pip and silence!
Users browsing this forum: Google [Bot] and 78 guests
