How to fit a new horn?
- Currently Drives:: meegane tourer diesel
Horn has died and I've got an MOT in a month, I've read it's a pretty easy retrofit, but no-one outlines how you get the front grill off, the official advice I believe is removing a lot more body parts. Any pointers, the advice I've read so far is a bit unclear. Cheers
Re: How to fit a new horn?
Remove the bumper as described in the manual. It is easier than you may think... and even easier that you will think after reading this post.
Don't break the upper clips when you take it off - an assistant and patience are both required. Also, compare the fuse rating for the new unit with its amperage. Otherwise, you will get a short pip and silence!
