AIRBAG LIGHT
evansgary9
Currently Drives:: megane
AIRBAG LIGHT
Postby evansgary9 » Fri Aug 05, 2011 1:53 am
Hi i have recently bought an 03 1.4 three door megane and have a couple of problems.
ok so the first problem is my airbag light all is ok when i start the car but after a couple of seconds there is a click from the door (sounds like door locking) not quite sure what this would be as only ignition been pressed then on comes the airbag light.
If anybody could give me an idea what the noise was and where to look i am sure this would be a simple fix.
The other thing is there is an abs fault pads and discs where done before i bought the car and are still in good order can i check and clean the sensors without taking calipers to pieces?
morganjake1544
Re: AIRBAG LIGHT
Postby morganjake1544 » Fri Aug 05, 2011 11:24 am
Re airbag light:- check connector under passenger seat is fastened properly. Because the passenger seat in the 3 door models is always being moved to let in rear passengers the connector can work loose.
chewbacker
Currently Drives:: megane 19 dci
Re: AIRBAG LIGHT
Postby chewbacker » Fri Aug 05, 2011 10:07 pm
the noise your hearing is the airbag system unlocking the doors as it would in a crash as it has detected a fault and is about to deactivate the airbag system. if the airbag light stays on until you turn the car of the steering lock should not engage.
as said morganjake1544 it is comon to be the wire or connector under the front seats. sometimes just a wiggle while vehicle is on is enough to put the light out. get a auto electrican to do the repairs as it is special wire and the wrong repair method would at best keep your light on at worst fire off a airbag.
renault would just fit new seat looms at a huge cost if you took it to them and this is not needed
arran.vigar
Currently Drives:: Megane II 03
Re: AIRBAG LIGHT
Postby arran.vigar » Sat Aug 06, 2011 11:22 pm
could someone please take a photo or something of the wires and upload them as I have the same issue but have no idea what wires I am looking for Ive spent hours under the seat trying to figure it out. and does anyone know what the relay is for under the seats?
tomalamix
Re: AIRBAG LIGHT
Postby tomalamix » Mon Aug 08, 2011 9:20 am
check this post here:
viewtopic.php?f=2&t=9127
good luck
arran.vigar
Re: AIRBAG LIGHT
Postby arran.vigar » Mon Aug 08, 2011 2:00 pm
Good find tomalamix I have been wondering what the plastic thing with the curled was for ages it's under my passenger seat but the plastic rail bit is missing but will find a new one now. Thanks very much
evansgary9
Re: AIRBAG LIGHT
Postby evansgary9 » Tue Aug 16, 2011 6:20 pm
I was missing the plastic rail so i put it back on and put the black box with the curly metal switch back on the metal bracket it clicks onto. even when the switch is in contact with the plastic pressing the switch the light still comes on. renault say the driver door will not close propperly could that be causing the problem.
tomalamix
Re: AIRBAG LIGHT
Postby tomalamix » Tue Aug 16, 2011 10:04 pm
you have to check both seats, both have that wires under the seats... :?
evansgary9
Re: AIRBAG LIGHT
Postby evansgary9 » Wed Aug 17, 2011 7:51 pm
thanks for all your help sorted this problem, the metal on the switch was pressing the button constantly just pulled it away a fraction and light went off placed the switch back on the bracket and activated switch , light came back on .
Started the car again no light :D .
Thank you all once again.
Users browsing this forum: No registered users and 64 guests
