Climate control
Baggieboy
Climate control
Postby Baggieboy » Mon Jun 06, 2011 9:38 pm
2008 1.5dci Dynamique CC
Air conditioning/heating seems to work fine if operated manually (temperature low/high, fan max) , however as soon as "Auto" is pressed the fan stops running and there is no airflow. Clearly the basic cooling/heating components are working.
Any ideas?
'08 1.5dCi Megane CC in Black
Baggieboy
Re: Climate control
Postby Baggieboy » Tue Jun 07, 2011 6:06 pm
After disconnecting the battery for a few minutes, the Climate Control seems to be working normally again. I went out today after the sun had warmed the car up and after a few minutes it was blowing cold at quite a rate.
