2008 1.5dci Dynamique CC
Air conditioning/heating seems to work fine if operated manually (temperature low/high, fan max) , however as soon as "Auto" is pressed the fan stops running and there is no airflow. Clearly the basic cooling/heating components are working.
Any ideas?
Climate control
Climate control
'08 1.5dCi Megane CC in Black
Re: Climate control
After disconnecting the battery for a few minutes, the Climate Control seems to be working normally again. I went out today after the sun had warmed the car up and after a few minutes it was blowing cold at quite a rate.
Users browsing this forum: Google [Bot] and 35 guests
