Oil light
Mattovplymouth
Currently Drives:: Renault megane 1.9 120 dci dynamique
Nissan R33 skyline gtst
Oil light
Postby Mattovplymouth » Thu Mar 17, 2011 6:34 am
Hi all
I know this has probably been covered but as for real info can't find much. Right down to the nitty gritty.....
Everytime I go round a corner, brake heavily or sharply accelerate my oil & stop light comes on. I know what the problem is as I had the same in my r33 skyline which I sorted with a large volume baffled sump when I had my rebuild/forge. The problem that the oil in the sump is being thrown around the sump away from the pick up pipe losing oil pressure triggering the oil light to come on. What I need to know is... Is this a common problem?? Oil level is right on the dipstick and on the info screen. It's a 53 reg 1.9 DCI dynamique by the way
Cheers all
Re: Oil light
Postby davelowe » Thu Mar 17, 2011 10:49 pm
It isn't common. I can't believe (well I can) that lateral cornering forces are at work here. What grade oil are you using?
direstraits
Laguna III Ph2 Exception
Re: Oil light
Postby direstraits » Fri Mar 18, 2011 11:33 am
Mattovplymouth wrote:Hi all
Cheers all
Are you sure it is oil light? No warning beeps? If there are warning beeps and stop light I would suggest you check the braking fluid level and/or change the pads and discs.
Users browsing this forum: No registered users and 139 guests
