Installing Aux cable - need advice
J4mie
Currently Drives:: Megane II 1.6 VVT Privilege
Postby J4mie » Fri Jan 28, 2011 5:43 pm
I have a Update List head unit and have read up about how to install an Aux cable alongside the existing CD Changer.
I've set head unit to expert and turned on Aux channel.
Have the necessary cable to plug into the back of the HU.
The problem I have is where to feed the cable to get out to the front of the car so my iPod can sit in the tray where the cup holders are.
I see that there is a panel of the dash right there that looks like it might be able to be removed, but I have no idea what is is - can anyone help me out?
Here's a picture of the area I mean:
Re: Installing Aux cable - need advice
Postby joeishmather » Fri Jan 28, 2011 5:51 pm
Yeah that pulls out, probably best running the wire down there, otherwise run it do it comes out under the centre part slightly infront of the gear stick n if u use a retractable six extension cable it hides neatly under there where no one canbsee n u just pull it out when you want it n place it music player infront of the panel you asked if could be removed, if you pull up the gear surround then you will find all the other central part around there pulls off, giving access to where I suggested to put your aux wire,
This explanation isn't probably all that clear, I'll take some pics if you want?
J4mie
Postby J4mie » Fri Jan 28, 2011 5:52 pm
I think I understand what you mean, but if you have some pics that would be much appreciated.
Thanks very much!
Postby joeishmather » Fri Jan 28, 2011 6:28 pm
I'll take you some tomorro,
Happy to help :-)
mattyc25
Currently Drives:: megane mk2
Postby mattyc25 » Sat Feb 05, 2011 4:12 pm
take the tray under the cd player out. drill a hole in the back of it take the cable through that.
Problem solved.
Postby joeishmather » Sat Feb 05, 2011 4:37 pm
He can't do that tho can he as he's got a cd changer, which would be there...
Also sorry I never got round to taking the pics, have you sorted it?
J4mie
Postby J4mie » Sat Feb 05, 2011 7:24 pm
Yes I've managed to sort it thanks.
I put the cable down into the passenger footwell and pulled it round to near the gearstick.
I couldn't work out how to get it further down, to come out at the bottom.
There's a kind of tray near the cup holders that pulls off (i think it's where the computer can be connected to check out errors etc) but I don't know how to feed the cable down that far.
I think the main problem I had was that I couldn't get my 6 CD Changer out.
Postby joeishmather » Sat Feb 05, 2011 8:01 pm
When the cables in the foot well did youbtake a panel off, if you bring the wire round to the bottom of where that bit that hides the connector for computer, below the centre console part with the gear stick and push the wire up, you should see it appear by the connector...
Not the best explanation! Lol
bbentley1980
Currently Drives:: Renault Megane 1.5 DCi 106 Dynamique 5dr Diesel Hatchback 2006
Postby bbentley1980 » Wed Mar 20, 2013 12:31 pm
Did you manage to install an aux cable and retain full use of your CD changer? I'm looking for advice on how exactly to do this. Also, best parts such as cables iphone holders etc.
