Hiya,
I have just got a 55 reg 1.4 Megane Oasis but have a problem with the CD player.
Im able to play CDS, change stations, bands etc but the volume is locked on 14 and whenever i press the volume up or down it does nothing and beeps loudly when i press eject. anyone else had this problem or does anyone know what i can do to rectify it? its the standard factory CD player
cheers
Chris
Unable to change volume
- Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
Re: Unable to change volume
on my megane I found a similar problem
I was driving to stoke so the radio started to loose signal
so i pressed number 2 the radio bleeped and tuned back in
then the radio would not turn back up
pressed number 2 again
and worked fine
and worked fine
