Rear brake Light above back window
nik_rowlands3
Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
Postby nik_rowlands3 » Wed May 26, 2010 6:43 pm
when I press the Brake this does not work is there a fuse I need to change or will I need to go buy a new unit
Damo2580
Currently Drives:: 2003 Renault Megane Privilege 2.0l petrol, in metallic black
Re: Rear brake Light above back window
Postby Damo2580 » Wed May 26, 2010 11:45 pm
Mine doesnt work at all either. Looks like whole strip will have to be replaced as it contains little soldered led bulbs rather than normal bulbs
pajopy
Postby pajopy » Fri May 28, 2010 1:22 pm
what type of megane are you driving? I had a same problem, but rear screen wiper didn't work, rear screen de-icing didn't work and tail gate lock didn't work. Also a fuse for rear screen wiper blown. I found out almost all wires in rubber tube on tail gate broken. :mad They are to hard or something because this was not for first time ...
I fix it for now, but I'll never know when will be next time ...
Megane 1.5 dci 100, grandtour, 2005.
Postby davelowe » Fri May 28, 2010 9:50 pm
nik_rowlands3 wrote:when I press the Brake this does not work is there a fuse I need to change or will I need to go buy a new unit
Not on mine. I took off the trim inside the hatchback boot lid and wiggled the connector. It was intermittent - indicative of probable soldered connection failings, or chafed wiring. I only found this out today, so I'll post up a solution should I find one.
Users browsing this forum: No registered users and 68 guests
