Rear brake Light above back window
- Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
when I press the Brake this does not work is there a fuse I need to change or will I need to go buy a new unit
- Currently Drives:: 2003 Renault Megane Privilege 2.0l petrol, in metallic black
Re: Rear brake Light above back window
Mine doesnt work at all either. Looks like whole strip will have to be replaced as it contains little soldered led bulbs rather than normal bulbs
what type of megane are you driving? I had a same problem, but rear screen wiper didn't work, rear screen de-icing didn't work and tail gate lock didn't work. Also a fuse for rear screen wiper blown. I found out almost all wires in rubber tube on tail gate broken.
They are to hard or something because this was not for first time ...
I fix it for now, but I'll never know when will be next time ...
Megane 1.5 dci 100, grandtour, 2005.
nik_rowlands3 wrote:when I press the Brake this does not work is there a fuse I need to change or will I need to go buy a new unit
Not on mine. I took off the trim inside the hatchback boot lid and wiggled the connector. It was intermittent - indicative of probable soldered connection failings, or chafed wiring. I only found this out today, so I'll post up a solution should I find one.
Users browsing this forum: No registered users and 71 guests
