hello...
everytime 1 of my rear indicators comes on aswel as the brake light?
does any no why this problem happens?
indicator comes on when i brake?
Re: indicator comes on when i brake?
Have you replaced a bulb recently?
- Currently Drives:: Mégane II Ph.1 1.6 16v Dynamique Luxe, full leather seats, Carminat Informé 1 with CD-changer.
It's a grounding problem, check for oxidated connections in the lampunit-connectors or at the groundingpoint. Did you have a waterleak in the lights, trunk or tailgate?
how do i do that?
water problems? now what i no about..
if i changed the light would it fix the problem? or is it in the wires..
because i disconnected the light and when i did i put it bk together and moved around
and it got dimmer?
and it got dimmer?
- Nige
Unscrew the rear tail-lights take out the plugs....Clean all the metal pins (to which the plugs connect too) on both the lenses.....and clean the plugs themselves with electical cleaner and a small thin nail....Scrape the connections to remove contaminates and bobs your uncle....fixed!
Common on many cars, just damp weather and corrosion
cheers mate ill do it in the morning
is ur megane a sport or u put the bumpers on?
do that and spray some silicone lubricant on them aswell
- Nige
vee wrote:cheers mate ill do it in the morning
Another Replica here dude...it's been fun tho!
