indicator comes on when i brake?
vee
Currently Drives:: megane r26
Postby vee » Wed Jan 13, 2010 9:18 pm
hello...
everytime 1 of my rear indicators comes on aswel as the brake light?
does any no why this problem happens?
Re: indicator comes on when i brake?
Postby davelowe » Wed Jan 13, 2010 10:54 pm
Have you replaced a bulb recently?
-KJ-
Currently Drives:: Mégane II Ph.1 1.6 16v Dynamique Luxe, full leather seats, Carminat Informé 1 with CD-changer.
Postby -KJ- » Wed Jan 13, 2010 11:12 pm
It's a grounding problem, check for oxidated connections in the lampunit-connectors or at the groundingpoint. Did you have a waterleak in the lights, trunk or tailgate?
vee
Postby vee » Sun Jan 17, 2010 3:57 pm
how do i do that?
water problems? now what i no about..
if i changed the light would it fix the problem? or is it in the wires..
because i disconnected the light and when i did i put it bk together and moved around
and it got dimmer?
Nige
Postby Nige » Mon Jan 18, 2010 1:38 pm
Unscrew the rear tail-lights take out the plugs....Clean all the metal pins (to which the plugs connect too) on both the lenses.....and clean the plugs themselves with electical cleaner and a small thin nail....Scrape the connections to remove contaminates and bobs your uncle....fixed!
Common on many cars, just damp weather and corrosion
vee
Postby vee » Tue Jan 19, 2010 2:33 am
cheers mate ill do it in the morning
is ur megane a sport or u put the bumpers on?
andywills
Postby andywills » Tue Jan 19, 2010 9:05 am
do that and spray some silicone lubricant on them aswell
Nige
Postby Nige » Tue Jan 19, 2010 11:12 am
vee wrote:cheers mate ill do it in the morning
Another Replica here dude...it's been fun tho!
Users browsing this forum: No registered users and 87 guests
