Radio problem (Dealer says it is normal)
pippa
Currently Drives:: 2004 1.6 16v Dynamique
Postby pippa » Tue May 12, 2009 7:01 am
Hi :)
I have just purchased a second hand Renault Megane II, it is a 2005 Dynamique 1.6 model. I have a problem with the radio.
It turns off after about 10 minutes, while driving the car. It beeps and then goes off. The dealer said he would look at that.
My question is about when turning the car off though. When opening the door, the aircon turns off etc, but the radio stays on. In my boyfriend's Renault it turns off too. (He has the sport).
I am going to the dealer this afternoon, but when I told him, he said it was normal, and shouldn't turn off when exiting the car. Is he right? OR should I ask them to look into it again?
Thank you very much!
Pippa
mgodden1989
Currently Drives:: Vauxhall Astra 1.4 16v SXi Twinport in Pearl Black
Re: Radio problem (Dealer says it is normal)
Postby mgodden1989 » Tue May 12, 2009 8:12 am
from what i can remember from owning my Megane, once the engine was stopped, everything stayed on, then as soon as the drivers door was opened, all of the electrics, and i mean all, lights, radio, A/C etc etc all switched off!
mine was also a 1.6 dynamique but on a 52 plate
hope this info helps!
EX Renault Megane Driver - now drive Vauxhall Astra 1.4 SXi 55reg in Pearl Black
My old Megane
sav0
Currently Drives:: Megane 1.5dci 53 Plate
Postby sav0 » Tue May 12, 2009 8:37 am
my radio used to turn itself off after 10 mins or so whilst driving .
I would check the fuse in the glove box , the guy I got my car off must have thought fuses were expensive cos he had just wrapped a paperclip around the old blown fuse to make a connection.
You will find your radio will also turn itself off when exiting the car as mine never used to until i changed the fuse
Let us all know how you get on
pippa
Postby pippa » Tue May 12, 2009 8:44 am
Hi there all, thank you for your help!!
I found a question on another forum with the EXACT thing wrong with someone else's car.
"Lights for the a/c and rear de-mist are not working.
Also the radio/ cd player a) doesn't switch off automatically when the drivers door is open and b) beeps then turns off whilst I drive. "
And the response was
"Check fuses - especially 15. If not that then check the earth, as may be tripping the electronics.""
So I am taking it to the Dealer on Thursday and can confidently tell him it is not supposed to stay on. And I think you are right about it being the fuse.
Very helpful here! Thank you. Will let you all know.
:D
kskinnercat
Currently Drives:: megane 2 1.5dci sport tourer
Postby kskinnercat » Sat May 23, 2009 5:45 pm
hi
have had same problem on my old 53 plate clio it had blown a fuse in one of the boxes (i think in side of glove box)
and i believe it is a warning signal it happened to me on way to hartlepool from stevenage and i had to turn radio back on manualy about 20 times
hope this is of some help
k skinner
nicksgr8
Postby nicksgr8 » Wed Jun 15, 2011 2:49 pm
I had this problem with my car today and changing fuze 15 works. The cigarrette lighter shorted out, blowing the radio fuze and preventing the air con from working. Weird
pippa
Postby pippa » Wed Jun 15, 2011 4:33 pm
They replaced the fuse and it worked - this was long ago, sorry for not updating. I since have a new car :D
