Brake Disc
sarah5uk
Currently Drives:: Megane 1.6 dynamique 03
Brake Disc
Postby sarah5uk » Mon Apr 27, 2009 9:21 pm
Is anyone able to help me ... i need to renew my brake disc and wondered if anyone knows a good place to get cheap ones? (just not renault prices!!!!!!) Also is it a job that can be done at home or do you need special tools for the job?
I have a 03 reg megane 1.6
busternlouie
Re: Brake Disc
Postby busternlouie » Mon Apr 27, 2009 9:21 pm
Front or rear?
sarah5uk
Re: Brake Disc
Postby sarah5uk » Mon Apr 27, 2009 9:23 pm
Both!!!
busternlouie
Re: Brake Disc
Postby busternlouie » Mon Apr 27, 2009 9:33 pm
You need to change both sets of discs and pads?
The cheapest place is probably a local motor factors. Many people on here have opted for "EBC Green Stuff" discs and pads and say they are an improvement over the OEM parts.
The rear discs should come with bearings and ABS rings already fitted.
Rough prices depending on where bought:
Front Discs - £50 - 70 each
Rear Discs - £60 - 90 each
Pads - £20 - 40 an axle set (4 pads)
They are all straight forward enough to change, although you may need a special tool to wind back the piston in the rear brake calipers.
anth_dci
Currently Drives:: Megane II DCi 120 Dynamique 52 plate
Re: Brake Disc
Postby anth_dci » Mon Apr 27, 2009 10:09 pm
sorry busternlouie but do NOT what ever you do got for EBC green stuff they are shite! go for any disks, preferably brembo. as for pads anything by mintex for ferodo (perferable the 2500 for road use but they arent cheap). The rear disks come with the wheel bearings built into them, so if you cant be bothered to press the bearings in (and i suspect you cant) you have to go with reno own which are roughly 120quid for the pair regardless of where you go for them.
busternlouie
Re: Brake Disc
Postby busternlouie » Mon Apr 27, 2009 10:59 pm
I replaced mine with OEM discs and Ferodo pads, so I couldn't comment on how good the EBCs are, but it's the general consensus on here they are an improvement over the OEM parts.
Toodeep
Currently Drives:: 5 Door Privilege 1.6
Re: Brake Disc
Postby Toodeep » Tue Apr 28, 2009 9:33 am
sarah5uk wrote: Also is it a job that can be done at home or do you need special tools for the job?
It's not a hard job at all if you have access to reasonable tools. There are a couple of Torx screws but no special ones are needed. It's not recommended you re-use the old hub nuts at the rear. It is best to clamp the hose above the caliper and open the bleed screw when pushing back the piston to stop the reverse-flow of fluid inverting the master cylinder seals. Get yourself a Haynes Manual (Ref 4284 - 368). £20 from Halfords or perhaps a bit less on eBay.
busternlouie
Re: Brake Disc
Postby busternlouie » Tue Apr 28, 2009 2:14 pm
Toodeep wrote:It is best to clamp the hose above the caliper
Clamping the hose can damage it so i would recommend not to.
TheFinn
Re: Brake Disc
Postby TheFinn » Tue Apr 28, 2009 2:55 pm
I must say I have rather poor experiences on EBC Greenstuff pads. :( Performancewise they were OK on the Twingo, but the friction material parted company with the metal backing plates on all the four front pads, and they were no more than five years old! :shock: Never happened to me with any other make of pads!
(I recently opted for genuine Bosch quality front pads made in India, which must be a promise of adventure!) ;-)
2,0 16V 6-speed manual: Image - Image
