STOP! light... any ideas?
xylast
Currently Drives:: megane 2
Re: STOP! light... any ideas?
Postby xylast » Sun Jul 19, 2009 6:54 pm
My 1.9dci 03 reg has exactly the same symptons. This usually happens when the car is on a downslope and braking! I have checked the fluid and the level is o.k. Did you solve your problem and if so, how?
leighmills33
Postby leighmills33 » Tue Aug 17, 2010 12:03 pm
My car has exactly the same symptoms!!! did you ever find out your problems? thanks
tomalamix
Postby tomalamix » Thu Aug 19, 2010 9:31 am
Hy there,
Maybe the problem is on the fluid level sensor it self. Im not sure but i think you can move the sensor manually and then see if the light comes on and off, that will give you a clue if the problem is the sensor with problems or not.
Cheers!
Martin190184
Currently Drives:: RENAULT MEGANE SCENIC DYNAMIQUE DCI 1.9
Postby Martin190184 » Fri Aug 20, 2010 1:54 am
I have an 03 10.9 dci megane scenic & it has the exact same problem.
taz
Currently Drives:: renault meganne 04 19dci 5 door
Re:
Postby taz » Tue Aug 23, 2011 7:32 pm
Had the same stop light andb brake light on my car, only flashes on steep hills. My brake fluid was at half way so i topped it up and the light has not come back on. :D
tomalamix
Postby tomalamix » Tue Aug 23, 2011 9:59 pm
watch out when youre going to change pads, the oil will come up again and eventually it will spill
taz
Handbrake repair
Postby taz » Wed Feb 08, 2012 8:19 pm
Just repaired my hanbrake, it was not latching on. The problem was the button mechanism, really simple to repair. The plastic holder within the handle was smashed in three places and was easily repaired by drilling and bolting back together. It too two hours and Iam not a mechanic. Well worth checking out could save you hundreds from a garage.
Users browsing this forum: No registered users and 83 guests
