Rough idle 1.5dci engine mount
steven-white
Currently Drives:: renault megane authentique 52 reg 1.6 petrol
Re: Rough idle 1.5dci engine mount
Postby steven-white » Sun Apr 04, 2010 6:12 pm
my engine mount snapped when i turned left out of a road, going slowly. gearbox dropped and cracked and mid exhaust has been moved downwards and cracked too. gearbox had to be sent away to be mended. unlucky eh?
revvinkevin007
Currently Drives:: 2005 megane dci 120
Postby revvinkevin007 » Fri Jun 18, 2010 3:18 am
Try cleaning your egr valve. They tend to get gunked up
2010popeye
Currently Drives:: fiat punto 55 shes a turbo!
Postby 2010popeye » Thu Nov 10, 2011 10:58 pm
HOW DO!
I have a scenic 1.5 dci ive got a rumble from the off side front mainly when in gear done track rod end, and drop link, brakes, and all round them bits look good! now i am looking at the top engine mount. Can anyone tell me how big the gap between mount and bracket on top is on a good engine mount??????? I can get my little finger in mine good fun but is this the norm?? :D :) :banghead like that one! :rock :banghead :banghead :pc
tomalamix
Postby tomalamix » Fri Nov 11, 2011 12:20 pm
there isnt a gap measure for that, at least i dont know one. ive managed to check them by visual examine the rubber. if its perished it must be swapped, a few cracks are acceptable. For the top right mount isnt like this, its hydraulic. The only really way to check it is to take it out and test it out side.
good luck
2010popeye
Postby 2010popeye » Sat Nov 12, 2011 3:21 pm
Tar mate! i will give that a go.
2010popeye
Postby 2010popeye » Sun Nov 13, 2011 6:11 pm
Top engine mount is shot think thats the prob :-) :pc
Postby davelowe » Sun Nov 13, 2011 10:52 pm
That engine mount resembles a dog bone. It is alloy in construction with a rubberised two-part interior. Removal is easy. Support the sump (trolley jack with block of wood) and raise the engine a few mm. A couple of 16/18/19mm bolts later, and a piece of cast alloy will leave it free to inspect. Check for obvious damage such as cracking, missing pieces, or total implosion (metal on metal contact such as filings). It should be pliable in all directions equally. Failure is normally very easy to see by eye.
2010popeye
Postby 2010popeye » Wed Nov 16, 2011 1:14 am
Top mount done sounds loads better but still not 100% gess its onto the rear mount now!
GOOD OLD RENAULT SCENICS THERE CHEAPER THAN mechanics courses! OR ARE THEY??????????????????????££££££££££££££££ :banghead
tomalamix
Postby tomalamix » Wed Nov 16, 2011 9:40 am
the other mounts can be visually checked using the criteria that ive posted before. can be other things such as steering rods, suspensions top struts, etc. unfortunately the list goes on...
cheers
2010popeye
Postby 2010popeye » Wed Nov 16, 2011 9:54 pm
THANKS But played it safe got mounts on order all 3> brand new ones gotta do something!
sending the old ones back to the garage i got the car from first class smashing job! :devil
tomalamix
Postby tomalamix » Fri Sep 20, 2013 11:17 pm
ive placed one 3 months ago, the engine still shake a LOT when im at 40 - 60 mil/h when i slightly put the foot on the gas and remove it, sometimes when i change chears and when im start to roll a little more fast, gives the sensation that the lower support bar is completely broken but is not, in fact ive made one crazy thing, ive swapped the lower mount by a steel bar, drilled the holes to fit correctly in the screw holes, it would not shake from there for sure, but guess what, it shakes anyway, the same way...right now ive replaced ALL the engine supports, shock absorbers etc, but i really notice that the upper support is very close to the bottom...it could be it...anyone have a picture how it should be? mine is 2 or 3 mm from the bottom but its a new part, FEBI by the way, it should be good..
craigyt
Postby craigyt » Sat Sep 21, 2013 8:40 am
Has anyone tried changing the engine temp sensor?
Mine does it aswel but tends to do it once in a blue moon when its warm but most of the time when its cold! Could it be a cold start problem from a dodgy coolant temp sensor?
Users browsing this forum: No registered users and 70 guests
