Engine vibrates on idle plus crap mpg
frankaai
Currently Drives:: 2005 Megane 1.9 DCI 120bhp
Re: Engine vibrates on idle plus crap mpg
Postby frankaai » Mon Nov 11, 2013 1:23 pm
let me know how you get on though
Bertisport
Postby Bertisport » Mon Nov 11, 2013 10:54 pm
I didn't even get home!! my electrics went Na-Na - although the I got the main relay box blown out and WD40'd and a DTC wipe, it ran great after that! a lot smoother
taffyhl
Postby taffyhl » Tue Nov 12, 2013 4:47 pm
Used to have a similar problem with my 1.9dci - shook even when nicely warmed up. It does still shake a bit now when cold but is ok when up to normal temp (2nd bar on the dial).
I took off the EGR, cleaned it up and tested it (check out the Pierburg website for details), unblocked the oil return pipe going from filler bottle to engine and cleaned out the intercooler and pipes. Also changed the air, oil & filter and fuel filter.
IMHO cleaning the EGR valve made the most difference as it was badly gunged up, causing the service light to come on.
When the car does occasionally get a bit shakey a good bit of welly seems to cure it!
frankaai
Postby frankaai » Tue Nov 12, 2013 4:56 pm
Bertisport wrote:I didn't even get home!! my electrics went Na-Na - although the I got the main relay box blown out and WD40'd and a DTC wipe, it ran great after that! a lot smoother
:/ sounds like a nightmare, whats DTC?....
frankaai
Postby frankaai » Tue Nov 12, 2013 4:59 pm
taffyhl wrote:Used to have a similar problem with my 1.9dci - shook even when nicely warmed up. It does still shake a bit now when cold but is ok when up to normal temp (2nd bar on the dial).
yeah i actually flushed the engine then serviced everything, the pipes surrounding the engine etc where all ok i put parts cleaner through them anyway just to be sure but the egr valve and inside the housing was covered in carbon, i didnt clean the pipe going from the filler bottle though nor the intercooler, whats this pierburg website?..... cheers for reply
Bertisport
Postby Bertisport » Tue Nov 12, 2013 6:03 pm
If i remember:
MAF sensor too late /interemittent
Main relay / interemittent
Took the car in foir its Safety recall (tail gate) and it wopuldn't start at the dealership so now having to pay multiple hundreds for them to change the UPC as they believe thats the issues as they found corrosion on multipugs and water ingress. :cry :cry
When we got it running last night and I drove it home it was the sweetest it had run.... EVER! if the ECU is fed off the UPC and thats giving intermittent current drops that could explain it running rough, mis-timed squirts(if you pardon thre term) leading to poor economy.
frankaai
Postby frankaai » Tue Nov 12, 2013 10:49 pm
Is the upc the lead going into the ecu? Sounds like an easy fix to me....
Bertisport
Postby Bertisport » Wed Nov 13, 2013 2:46 pm
EEEEEEEEEEEEEEEEEVERYTHING seems to go the UPC, body control stuff like central locking,engine stuff injector control -all powered directly or indirectly from this overgrown fuse tray.
tomalamix
Postby tomalamix » Wed Nov 13, 2013 10:38 pm
injectors were checked? ive read the thread across but ive not noticed any injectors check. did you made it?
frankaai
Postby frankaai » Wed Nov 13, 2013 11:12 pm
Injectors are fine because it's idling fine, no knocking noises either and it pulls well
tomalamix
Postby tomalamix » Sat Nov 16, 2013 9:54 pm
the topic says "engine vibrates on idle..." and you say the cabin vibrates on idle. i would check the injectors. its easy and eliminates one source of problem
cheers
Bertisport
Postby Bertisport » Sun Nov 17, 2013 10:32 pm
Car back from dealers, I'm now a lot poorer.
Car has donw over 140miles to day with no random electrical senility, MPG is back into the low-mid 50's cruising at "around 70 officer" for the motorway legs of the journey. Still got the neavy vibration when cold sitting at the lights though, might go back to my original plan of a injector cleaner and a EGR cleanout.
Postby AlexB » Mon Nov 18, 2013 1:05 am
This vibration looks like the top engine mount. The ECU makes the warm engine to idle lower when stationary. I had it once with F9Q-800: coasting to the traffic light, everything is OK, then stop and here the vibration begins...
frankaai
Postby frankaai » Mon Nov 18, 2013 9:07 am
i really dont think its injector as its not off a cyclinder at all, the power is still there and no knocking noises..... i think it would be a waste of time to do any tests on the injectors.... my mechanic said the engine mounts are fine....... its strange as sometimes it doesnt vibrate...
Postby AlexB » Mon Nov 18, 2013 10:05 am
It does not vibrate sometimes because the revs do not fall so low for some reason. Read the manual for the conditions when the idle revs become slightly elevated. It is a silly thing whose only purpose is to reduce your road tax... I am guessing, of course. Have a look yourself at the mount point. There should be a gap between the rubber and the metal bracket above it. Check also if it is installed by the old marks on the paint. Check the torque of the bolts, the table is in the manual.
