Tyre pressure sensors - removing them!
LeeUK
Currently Drives:: 1.9dci Sport Tourer Privilege, standard, 17s, in-dash 6cd cubasse
Honda S2000
Postby LeeUK » Tue Feb 15, 2011 10:32 pm
Im thinking of taking the sensors off, one is damaged on the outside so needs sorting but they are doing my head in
Can anyone tell me if i remove one or all if it will show as puncture or not show anything
1.9dci Privilege, Sport Tourer 17s Nervasport, cabasse
Honda S2000
TubaPlayer
Currently Drives:: 2004 (54) Black Megane 2.0T Privilege CC
Re: Tyre pressure sensors - removing them!
Postby TubaPlayer » Wed Feb 16, 2011 12:49 pm
If you remove your sensors the wheels will flash on the dash indicating that they are not recieving a signal unless you have them disabled using a CLIP
Megane 2004 2.0T Black Privilege CC, Xenons, Sat Nav, Cruise Control, Full Leather, Rear Parking Sensors (Colour Coded)
Previously: Megane 2003 2.0 16V Black Dymanique Sport Hatch
Postby Paddy » Wed Feb 16, 2011 5:13 pm
You can remove them from the wheels then have the feature turned off using a CLIP (Renault Diagnostic toll) They normaly charge £25 for the 4 second job. :banghead
If you remove them and dont have it deactivated every time you turn on the car it will say 'Tyre monitor communication error'.
LeeUK
Honda S2000
Postby LeeUK » Thu Feb 17, 2011 4:58 pm
thanks
I might replace one thats damaged and try and rest the others to prevent errors
although a mate tells me to check the weights, old style might be causing loss of pressure
Honda S2000
