Hi All
done a search but cant find anything
have a 53/04 megane 1.5vvt 5door
the the car thinks the front passenger door is always open, this is causing problems with lights not going off and not being able to lock the car.
anybody know where the sensor is, also is there anyway to bypass it. i presume its in the locking mech as i cant see any sensors on the door shuts.
Barrie
door wont register as closed
Re: door wont register as closed
hy,
The sensor is inside the locking mechanism. You can test the system. Here is a picture (not a actual megane but it can be used for this test):
https://www.2carpros.com/images/articles ... _reset.jpg
Where the screw driver is fitted you will find a movable lever, lets call it like that. That lever must be pushed against the door until it locks. Be carefull, dont actually close the door without first pulling the door handle like in the photo until that lever releases to its the initial position.
When you push that lever against the door and it locks the signal inside the car should be disabled, in other words, you "have" all doors secured closed. If that doesnt happen then you have some fault inside that lock. The lock can be accessed dissembling the door cover.
good luck
good luck
Hi all
anybody have access to Renault parts, i need a part number for the front passenger door locking mechanism for a 4/5 door Megane 2 1.6 vvt
also dephaser is gone, timing belt needs doing to, will this kit cover everything
https://cgi.ebay.co.uk/Renault-Megane-Sc ... 5d2b748a91
expensive month
after all the stick i have my mum for not selling her clio after all her problems i fallen into the trap, never again will i buy a Renault
expensive month
the problem on the door is inside the lock?
