225 SPORT REPLICA DCI ** (JULY 2012 UPDATE) **
- Sadret89
Re: 225 SPORT BUMPER ON MY DCI ** (JANUARY 2011 UPDATE) **
Well I've got the drivers side headlamp for the mk2 ph1 with the xenon lens but I need a passenger side one to complete the set, if I can ever find one!
- Currently Drives:: Megane dci 2005
Bad news. My mechanic says that the 225 back box has 2 mounts and my dci back box only has one. To fit the 2nd mount he says it's not do able as where the 2nd mount needs to go is plastic (spare wheel area).
Could anyone supply a photo of underneath to show how its done?
Help!!
Help!!
A friend of mine had his wealded on in 1 point n then the rest was just in the normal hangers...
Sadret89 wrote:Well I've got the drivers side headlamp for the mk2 ph1 with the xenon lens but I need a passenger side one to complete the set, if I can ever find one!
Well untill that time, I would remove the HID bulbs.
Buy a set of philips ultra white +90% bulbs in the mean time.
Even if you buy the phase two head lights with the concave lens. It needs to be the set with the auto balance motor fitted and sensor plug (sensors on the subframe). (ie two different set of PH 2 head lights)
Sorry to get at you. Just I fecking flip when muppets blind me with 'ebay special' hid kits.
On a side note, the grills are on there way. Posted them after work today.
- Sadret89
Cheers paddy, I've found and xenon headlight on eBay for £120 each and for the ph1 so unlike the ph2 ones, the mounts are exactly the same, the guy it should be a straight sway. However true that is.
Sadret89 wrote:Cheers paddy, I've found and xenon headlight on eBay for £120 each and for the ph1 so unlike the ph2 ones, the mounts are exactly the same, the guy it should be a straight sway. However true that is.
If you purchase them you will also need the leveling sensors that bolt to the subframe.
Then coded to the ECU.Through Clip
- Sadret89
**UPDATE**
Thanks to Paddy (ulrich) I recieved the top grills for the front bumper and now is complete!
Pictures will be added tonight.
- Sadret89
Re: 225 SPORT BUMPER ON MY DCI ** (FEBRUARY 2011 UPDATE) **
I have fitted the grills (thanks to Paddy), and some drilled and grooved brake disc with black stuff pads.
- Sadret89
Re: 225 SPORT REPLICA DCI ** (MARCH 2011 UPDATE) **
I thought I do another quick update.
As some may know from another thread, I changed all the bulbs to LED's!
And today, with a special thanks to Eddie for his help, change the speedos to the sport ones. Literally 5 minute job with Eddie's clear instructions, piece of cake.
Now I need help!
I've got the service light on with the error message of "Tyre Pressure Sensor Unknown" which obviously means it cannot read the the sensors which the car doesn't have.
I want to remove that error so the car doesn't look for sensors. How do I go about doing this?
Now I need help!
- Currently Drives:: megane II 2.0 DYNAMIQUE black
Looks bang tidy mate, where did you get all the led bulbs from ??
Was this a new set of clock, or simply replacing the 'dial card'
If its a new set of clocks, they need programed ' so to speak' and thus throw up errors / service light.
But in saying that I wouldn't have guessed a TPM sensor fault unless the car the clock were from had the sensors fitted. (either way will need hooked to the CLIP)
I have one here if you want to call by?
- Sadret89
They are an new set of clocks and not just the dial cards Paddy.
I went to Renault and like you said the previous car must of had TPS fitted so it searches for them in my car which I dont have.
The stealers reckon its a 30 minute job at £62.10 inc.VAT to turn it off.
Stevie messaged me and that what he did to his one as well.
- Currently Drives:: Renault megane 1.9DCI
Sadret89
Are them bulbs you have in your fog lights LED's?
If so where did you get them from and how much were they
Many thanks
Many thanks
