Door handle 'chrome' cracked
oldbury863
Currently Drives:: Eclipse 1.6 Dynamique (07)
Postby oldbury863 » Sun Jan 09, 2011 3:01 pm
The chrome (only on the rear part of the door handle that doesn't move) is cracked & starting to peel. Not only does it make the car look tatty, but this is now happening on 2 of the doors & the car is only just over 3 years old :mad . Is this a common problem, & is it possible to replace this part without the probable expense of replacing the entire door handle(s). I don't have hands-free locks. Any advise much appreciated.
pw981
Re: Door handle 'chrome' cracked
Postby pw981 » Sun Jan 09, 2011 3:32 pm
This is a common problem, I had mine replaced during the warranty period, only for it to happen again a few years later. You say your car is just over 3 years old, what is your mileage? I suggest you take pictures of the door handles, print the pictures and enclose them in a polite letter to Renault UK customer services explaining how disappointed you are that they are cracking/peeling and how you expect the quality to be of a higher standard and to last longer than three years.
I had a similar issue with a flaking/peeling gear knob insert (where the palm of your hand touches) at 2.5 years old, wasn't covered under warranty so I took pictures and sent a letter and presto, Renault covered the cost.
2004 Megane II 1.9dCi
oldbury863
Postby oldbury863 » Sun Jan 09, 2011 10:09 pm
Thanks for the reply. I'll definitely take some pictures and give it a try. . . . .
123*reggie
Currently Drives:: Renualt megane 1.5cdi (80 dyo) blue
Postby 123*reggie » Sun Jan 09, 2011 11:01 pm
oldbury863 wrote:The chrome (only on the rear part of the door handle that doesn't move) is cracked & starting to peel. Not only does it make the car look tatty, but this is now happening on 2 of the doors & the car is only just over 3 years old :mad . Is this a common problem, & is it possible to replace this part without the probable expense of replacing the entire door handle(s). I don't have hands-free locks. Any advise much appreciated.
if i may ask how much was the parts ? mines starting and im going to change them quick :-) 04 plate though :shock:
darkmast3r
Postby darkmast3r » Wed Jan 12, 2011 4:19 pm
I got some chrome handle covers from ebay, 20 quid for a set of 4, car looks very good and they fit well.
https://cgi.ebay.co.uk/renault-MEGANE-II ... 255fc7939d
TubaPlayer
Currently Drives:: 2004 (54) Black Megane 2.0T Privilege CC
Postby TubaPlayer » Sat Jan 22, 2011 7:29 pm
Try http://www.renaultpartsdirect.co.uk they seem to stock everything you could need (ish)
Megane 2004 2.0T Black Privilege CC, Xenons, Sat Nav, Cruise Control, Full Leather, Rear Parking Sensors (Colour Coded)
Previously: Megane 2003 2.0 16V Black Dymanique Sport Hatch
oldbury863
Postby oldbury863 » Mon Jan 24, 2011 7:19 pm
In case anyone was hoping to replace just the cracked part of their door handles (a fairly common problem) , I've just had a reply back from Renault parts direct . . . . .
Apparently the handle is only available complete for the sum of £64.26 each!! :shock: Think I'll get 4 stainless steel covers from e bay for £20 instead!
TubaPlayer
Postby TubaPlayer » Tue Jan 25, 2011 9:47 pm
