wipers and water
Re: wipers and water
Postby davelowe » Sun Dec 05, 2010 10:43 pm
Take off the bumper and replace it/test for voltage under operation.
Get some quotes from dealerships and parts suppliers if it is faulty.
megane10
Currently Drives:: Renault Megane II 52reg, 1.6VVT 16v
Postby megane10 » Tue Dec 07, 2010 11:15 am
Take off the bumper????
Postby davelowe » Tue Dec 07, 2010 10:43 pm
megane10 wrote:Take off the bumper????
Yes - it sounds like a big job but takes 15 minutes. I'm being serious. Paddy aka Ulrich does this to change his headlamp bulbs.
Have a search - the process must have been described many times.
megane10
Postby megane10 » Fri Dec 10, 2010 10:43 am
Yes, I have read about people taking off their bumpers in order to change the headlight bulbs.
I'll check for voltage and if needs be change the part. (Not a good look carrying around a bottle of water to splash on the windscreen!)
Thanks for your reply.
tomalamix
Postby tomalamix » Sat Dec 11, 2010 12:42 pm
Its cheap, its cheapher if you buy a Peugeot water pump, the 307 model has the same water pump, the brand Renault, Citroen and Peugeot are engraved on the motor. Just take it out and go to the Peugeot garage and buy one. You can also have a problem with your lever, the problem may be there too..
Vic87
Currently Drives:: Megane mk2 54reg
Postby Vic87 » Fri Dec 18, 2020 1:00 pm
How do I reinstall the wiper motor and linkage back in car im having alot of trouble with it
