Help took out window switch
McLaren
Currently Drives:: Megane
Postby McLaren » Wed Oct 13, 2010 4:05 pm
Hi all Pulled out the drivers window switch ok but sum thing drop in door when i put switch back in door the switch is moving what is the clip and can i get of ebay.
PS Took of as coved it in carben fiber looks good.
Re: Help took out window switch
Postby joeishmather » Wed Oct 13, 2010 4:16 pm
any pics, also why cant you just lift the top section of the door to retrive the part you think has dropped?
McLaren
Postby McLaren » Wed Oct 13, 2010 4:19 pm
Hi there how you take top of?
Yea it is a clip that holds the top bit of window holder for switch's to door.
Postby joeishmather » Wed Oct 13, 2010 4:33 pm
you unscrew the handle leaver and the pull handel, (3 screws in all) th epull handel s screws are covered but the front of the pull handel comes off, just pulls off, use a spoon or something to get it off so as not to damage it.. then after removing all the crews gently pull the apulstered part of the door from the bottom, this part hinges upwards, the 'hinge runs along the window' and theres your access! :-)
.......err, thats the best i can describe it really, but just ask if you want more explination!lol
McLaren
Postby McLaren » Wed Oct 13, 2010 4:36 pm
Thanks will give that a go tomoro.
Postby joeishmather » Wed Oct 13, 2010 4:44 pm
what type of carbon wrap did you use,
i just done my wing mirrors-http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=13&t=14820 its a nice stuff to use and acctually fairly easy too!!
McLaren
Postby McLaren » Wed Oct 13, 2010 5:00 pm
I used the 3M Di-Noc and it was very easy to use well happy with it am wanting to do my mirrors as well and the pillers.
Was it easy to do the mirrors then?
McLaren
Postby McLaren » Wed Oct 13, 2010 5:17 pm
Postby joeishmather » Wed Oct 13, 2010 5:25 pm
looking good, replied to ur question on the other post :-)
McLaren
Postby McLaren » Wed Oct 13, 2010 7:56 pm
http://www.flickr.com/photos/54803682@N03/5078714257/in/photostream/
This is where they was a clip and will not hold still in the hole now what is the clip name lol
