what pcd etc is a megan cc?
hi guys&girls i have a megane cc 57 plate i know there 4 stud but are they 4x100 or 4x108 ? whats the hi and lowest wheel offset i can get away with? cheers guys on and hiya im new on here lol
- direstraits
Re: what pcd etc is a megan cc?
4x100x60
cheers for the reply i thout it was 4x100
direstraits wrote:4x100x60
what is that in English?
PCD - Pitch Circle Diameter, or if you like, the distance between the centre of the nut holes across the bore diameter.
- direstraits
wanda wrote:direstraits wrote:4x100x60
4 = four screws
100 = the distance between the centre of the nut holes across the bore diameter
60 (60,1) = bore diameter, i.e. centre hole on the wheel
ooooh ok
