Front Wipers.... FLAT OR STANDARD????? please help....
dean-weston
Currently Drives:: 54 Megane 2 - 1.6VVT
Postby dean-weston » Mon Sep 27, 2010 1:46 pm
Hi guys, just a quick one.... I've just called to order some new front wipers on my 54 1.6 5-Door Megane 2 - they asked if i needed "flat" wipers or the Standard ones.... as there is 20 quid between them and only use the car for 40 mins a day i opted for the cheeper "standard" wiper, at which point she told me if i had flat ones i'd have to buy flat as the others wouldnt fit......... is this correct ??? :hm
Ray
Re: Front Wipers.... FLAT OR STANDARD????? please help....
Postby Ray » Mon Sep 27, 2010 4:01 pm
yes she's correct but it doesn't apply to you.
The newer "flat" blades are on modern cars and on the phase 2 and 3 meganes. They have a different arm to the standard wiper arm (with the U bend at the end) and so standard blades don't fit on them.
With the older U bend wiper arms, you can get standard bow type blades or get "retro fit" flat ones. personally, I think you should get the kind that came with the car. I found the retro fit ones aren't as good unless the car was designed to take them (in which case they're actually standard fit but a different design wiper altogether)
bigstring
Currently Drives:: 1.9DCI
Postby bigstring » Sun Oct 03, 2010 7:06 pm
I think the flat blades look a lot better and can purchase half decent ones off ebay for around £7......... first thing I do when getting another car, flat blades.....
